    Results 1 to 7 of 7
      4th gen F-body wheels on a 68-72 A-body
      Anyone know if a set of 17x9.5 and 17x11 wheels for a LS1 f-body will fit a 68-72 a-body?
      -Jason
      Jul 2002
      Mesquite, TX
      They *might* fit with spacers; the offset is way off for them to fit without them.
      Not sure you'll fit an 11" wide wheel under an A-body regardless without narrowing the frame rails though.
      Nov 2002
      Georgetown,TX
      A 17x9.5 and a 17x11 will fit under a 68-72 Chevelle or El Camino if the backspacing is correct.
      Mar 2003
      Rochester, MN
      Quote Originally Posted by payne
      -Jason
      They'll fit fine. I have them on my '70 El Camino. You'll need 1" wheel adapters with the correct offset wheels. There are different offsets so you have to make sure you get the correct ones. Measure, measure, measure!
      Keith
      '09 Viper SRT-10X
      70 El Camino SS L78 396
      Chevy High Performance Feature
      May 2006
      Statesboro, GA
      Quote Originally Posted by KAA
      What bs do you have? Is the car mini tubbed or anything?
      Mantorville, MN
      There is 13+" (varies from car-to-car, but usually ranges 13 - 13.25") of space in the rear of a 68-72 A-body, and a 315/35/17 runs about 12.5" wide, so it will fit, but it's damn tight.
      Backspace *should* be around 5.5" in front and 6.25 in rear for 9.5 and 11" wheels, but brakes, spindles, etc will have an effect, so measure carefully!
      May 2006
      Statesboro, GA
      What do you usally measure? I have never bought a set of wheels.
