View Full Version : 2 high front end
Nova73
08-03-2006, 07:51 PM
well i have yet another dilema, I have moroso trick front springs, 3 way adjustable shocks up front, stock leafs with poly pads, and cal trac bars with 3 way shocks in rear also, I have 17x8 centerlines in rear with 255/40 17 and 17x7 with 225/50- 17 in front. i cant run drop spindles because i havent found any good ones that the tie rod wont rub the rim, and im pretty damn sure i cant cut, nor do i want to cut my trick springs. I would like the front to sit around 2" lower in front because i have alot of air between the tire and fender lip in the front and none in the rear and it looks stupid. any suggestions?
NvrDun71
08-03-2006, 07:55 PM
AFX spindles if you can cough up the coin for a set
08-03-2006, 09:54 PM
Moroso's are trim to fit. You can cut off about an inch off the bottom. Or buy a set of lowering springs from Hotchkis, Eibach, or DSE etc... ahhh coins?
Nova73
08-04-2006, 04:57 AM
Ya i just read in their catalog u can cut of one half coil to change ride hieght. guess thats what ill do first
