    Results 1 to 6 of 6
      Nov 2004
      Pickering,Canada
      anyone used speed tech brackets?
      just wondering if anyone here has used speed tech C5 brake conversion kit.It uses the original drum spindle and hub with slight machining to the outside of the hub.The C5 rotors will then slip on as well as the rest of the C5 stuff! any info would be great.
      Jul 2002
      Mesquite, TX
      I've got the adapters in a box in my garage, they're very pretty but I haven't installed them yet. I got them in a GP from GPSuperstore.
      Jul 2002
      Mesquite, TX
      Erm. Sorry. I've got the kit to use a C5 caliper on the C4 rotor. Apparently they don't do the C5/C5 kit anymore.
      Portland Oregon
      My Supplier has them in stock. PLus Caliper, rotors and Brackets.
      Speed Tech is a little slow on supplying since demand was so high and they are developing Ford Stuff now.
      Sep 2004
      savannah,ga
      I have the brackets for the c4 rotors and c5 calipers, works good, fits perfect, looks cool, easy to do.
      Nov 2004
      Pickering,Canada
      Tom..this kit do you have to use C4 rotors but use C5 calipers,pads and brackets? They say to use all C5 stuff including front rotors.Im confused..also can I use my disc spindles?
