    Results 1 to 3 of 3
      Aug 2005
      Will aftermarket brakes for a 4th gen f-body fit a 1st get f-body?
      Looking at some willwood brakes that a guy has for a 4th gen firebird/formula. I was wondering if they would fit a 1st gen camaro. My car is currently a 4 wheel drum brakes setup. What would it take to make this work?
      Dec 2002
      Lost Wages, Nevada
      To make it work, probably just the brackets required to bolt the calipers to your spindles and rear end housing. But I am pretty sure that the hat offset in the rotors might be another issue in a swap like this.
      Sep 2004
      savannah,ga
      If they are stock replacement parts, in other words they fit the stock 4th gen brackets then I would guess that they would work with the Speedtech brackets or something similar. I am using 4th gen camaro calipers with my Speedtech brackets and c4 13" rotors.
