    Results 1 to 6 of 6
      Grand Rapids, Mi.
      Painting aluminum closeout panel
      I have a DSE closeout that I want to paint the body color. I'm using PPG products. Should I spray a coat of the DP epoxy primer first or should I put down some K36 high build first.(to fill the scratches). Also, Do I need to "rough it up" a bit to get the primer to stick? Thanks, John
      1968 camaro rs convertible, 02 LS1/4L60E
      prep
      sand with 320, ep prime, then wet on wet into high build, if you think high build will fill the scratches, then sand high build with 320 then 400 seal and paint or finish in 600 and go right into basecoat
      Ocean View, Delaware 19970
      I powder coated mine. They have all kinds of colors. I'm sure they have one close or even a perfect match for you. I had 40 bucks in getting mine done.
      69 RS Rat. Ocean View, De. 19970 If you wake up and you can put your feet on the floor, IT'S A GOOD DAY!!!
      Grand Rapids, Mi.
      Thanks guys.
      Sterling Heights
      What DSE closeout are you talking about? Doing the final strip down of my 69 Camaro and want to get an accurate list of what I want the body shop to do.
      Grand Rapids, Mi.
      Its an aluminun panel that covers the area between the header panel and the radiator.
