    Results 1 to 3 of 3
    Thread: alignment help
      Port St. Lucie FL
      alignment help
      guys i need to know many shims you guys use in the suspension of your 69 camaros i redid my front suspension and there wasnt any shims in it when i took it apart...i can do the alignment at work but i dont wanna put excess wear on my new tires getting it there
      Kacy
      79 Corvette, 406 SBC, Holley EFI, 700R4
      dennis68 Guest
      It varies depending on a thousand different variables. How much has your ride height changed, how much have has the cradle moved since it was built, how many front-end components have been changed, where were the shims to start with? There is no way to determine how many shims you need or where they need to go. If you have enough knowledge to align your own car you should be able to eyeball it on the ground by yourself. There are also half a dozen different shim thickness' so where one guy may have 3 shims in the L/R shim pack (1/4") another guy my have 6 shims (1/8").
      Nov 2002
      state of confusion
      If he's got a level driveway, a little patience and some common measuring tools is enough to get it very close.
      Norm
      Gone but not forgotten dep't:
