Results 1 to 12 of 12
Thread: Can This Roof be Saved
07-27-2006 #1
- Join Date
- Oct 2005
- Location
- Middleton, Idaho
- Posts
- 68
These are pictures of the left front corner of the roof of my 69 RS. There is no outside surface rust, but the steel was so thin in four areas that I was able to push a screwdriver right through it. I've already cut rust from the windshield recess area, see picture and started spraying Metal Ready on the panel from underneath. Can I save the roof panel by using all metal or POR 15 or should I cut out the thin areas or should I just cut the roof off? Any help will be greatly appreciated. I've already replaced the quarters and have yet to weld the roof to the new quarters.
Steve Spoor
Middleton, Idaho
69 Rally Sport w/T-56, Quadra-Link, Wayne Due C-4 Clip, 420 SB2.2
67 Chevelle, Art Morrison Chassis, 416 LS3, Inglese 8-Stack Injection
2014 Ext. Cab Silverado, Lowered.
07-27-2006 #2
- Join Date
- Apr 2006
- Posts
- 1,027
roof
put a roof on it and be done, the dynacorn roof fits nice, i just finished doing one yesterday
that roof is done,
note, melt the lead out with a torch, do not grind it out, even a little propane torch with map gas will work perfect
, i only trimmed the lip that sets inthe rain gutter channle so i could square up the roof, then glue the rails and weld the sail panel and front and rear window channelLast edited by TonyL; 07-27-2006 at 03:02 PM.
07-27-2006 #3
