Results 1 to 4 of 4
07-25-2006 #1
- Join Date
- Mar 2005
- Location
- Salinas, CA. 4.5 MI from the Corkscrew @ Laguna Seca
- Posts
- 62
68 Camaro rear deck filler panel replacement
I pulled the rear window from my 68 Camaro the other day and found the usual Chevy muscle car rust along the rear panel between the window and trunk. Classic Industries calls this the "Upper rear outer body panel". Since it's only @ $80.00, it seems to me to be almost as easy to replace the entire panel than cut and repair/replace three quarters of the window channel on this panel. But since I've never done it before, how hard is it? Has anyone done this before? What should I look for, what should I avoid. I'm not the best bodyman, but between me and some friends, I think it may be something that could be done in the garage. What do you think? Thanks in advance for the advice, TZ.
08-01-2006 #2
New to Pro-Touring
- Join Date
- Mar 2005
- Location
- Sterling Heights
- Posts
- 91
I have a 69 Camaro, that HAD a vynal top. Sounds like same problem. I already ordered a replacement panel. I don't know what it will cost to put in, anyone know ruff shop hours to install? Is there a site with panel replacement estimate times? I also have the rear tail light panel that I'm thinking of replacing. Thanx
08-01-2006 #3
