View Full Version : 4th gen booster
SICMARO
07-21-2006, 08:26 PM
i want to use a 4th gen camaro booster and master in my 2nd gen. mounting the booster looks simple. only question is what to do with the rod to the pedal? my stock one is almost 4 inches longer then the 4th gen. anyone done this conv? thanks!!!!
EFI69Cam
07-22-2006, 11:25 AM
The 5th gen vette one is a closer fit. You will have a fab up or modify mounting brackets, but the shaft is quite a bit longer. HTH
barno68
07-28-2006, 07:23 PM
I have a 4th gen corvette booster that I am putting in mine, but have not got it over to the shop to mock up yet. However, the shaft measures the same and the mounting studs are also the same, the only modification I can see needed is enlarging the brake lever mounting hole.
SICMARO
07-30-2006, 08:49 PM
the 4th gen camaro mounted to the fire wall just fine for me. i grinded and drilled out the factory studs and it bolted right up. i will have to make a notch in the firewall where the push rod enters the cab and lengthen the rod to reach the pedel.
