    Results 1 to 4 of 4
      Sep 2004
      Metamora, Illinois
      Anyone using DEI Floor and Tunnel Shields?
      I was thinking about applying a couple of these above the mufflers and transmission on the underneath of the car to help reduce heat and sound inside the car. Anyone here using these or something similar? Also how well do these hold up on the underside of a street driven car?
      http://store.summitracing.com/partde...5&autoview=sku
      Sep 2001
      Accord, NY
      I've had it on for three years in places where my pipes are about 1/4" from the floor. Not easy to maximize ground clearance on a vert with my x-pipe! It's held up well. I don't think you'll see any effect on sound control though.
      69 Camaro convertible, 410, M22, 8-pt cage therapy program. SOLD.
      68 camaro - SOLD
      67 Bel Air - New street project with perfect floors, frame and trunk!
      Sep 2004
      Metamora, Illinois
      Quote Originally Posted by Rick Dorion
      I don't expect this to reduce the sound like their ad says, but more for the heat reduction. I measured the heat,on the trans tunnel between the seats, with a infrared heat gun at it reads close to 120 degrees. Did you only apply it above the exhaust pipes or did you do the trans tunnel.?
      Sep 2001
      Accord, NY
      I only applied it where the pipes came close to the floor. I had painted the underneath and didn't want blistering, etc. Down the length of the tunnel my system is probably 3/4-1" away and I haven't seen a problem.
      68 camaro - SOLD
