Results 1 to 4 of 4
- Join Date
- Oct 2004
- Posts
- 1
have 12 bolt need brakes 72 chevelle wagon
15in. wheel. looking at late s-10 blazer rear disc looks like all most a direct fit the axel could be turned down to fit the rotor how do i deal with drum type (E) brake cable
10-28-2004 #2Re:
I put a moser 12 bolt in the Nova a month or two ago and Wilwood had a disc brake setup for around 500 or so I think??? It was a 12.19 inch rotor and 4 piston billet caliper. Fits inside of my 15" Weld Pro Stars, clears by about 1/16th" to an 1/8th". The 12 bolt I ordered was a pressed in (do I dare to say it) "Ford style" bearing. But I am sure if you called Wilwood they have a regular kit for the standard 12 bolt.
10-28-2004 #3Hey, the rear disc setup (you need everything minus ebrake) from a 98-02 Camaro/Firebird LS1 car will bolt right up!!
09-29-2005 #4
- Join Date
- Aug 2005
- Posts
- 198
Anyone hooked up their stock pedal to LS camaro e-brake?
68 Chevelle SS396. Pro-touring in Progress
Pro-jected 396, TKO 600, 3.90'd 12 bolt, LS1 brakes.
