Results 1 to 20 of 44
07-11-2006 #1
- Join Date
- Aug 2004
- Posts
- 378
What to expect to spend for the work? Need to make a decision.
my car needs repainted, was done once about 6 years ago but due to various issues, not the least of which was the shop, needs new paint.
So, I'm trying to figure out what to budget so that I can either paint it and continue or just concetrate on the mechanicals and tear it down again later or sell it.
Since it's going in, I need a few holes welded up 1/4" or smaller. I also want to put the DSE fill plate in the firewall, and put mini tubs in it. Needs put back on a rotissery(sp) and the underside coated and the dash and door jabs redone. Body work is 90%+ and car is only about 40% assembled, but I'll take care of the engine removal and such if needed.
Solid color, body color(most likely) in the engine bay and dash, dark blue. Prodigy Custom fastners used to re install front metal Maybe a stripe around the nose, but nothing fancy.
Think that's it.
07-11-2006 #2Depends on how straight you want it. I spoke to Jon Byer in Washington with metal work and all and he quoted me around $30,000 - to $60,000 for my project. I would say that you are looking in the $20,000 to $40,000 range but, again, depends on how straight you want it. You might want to look at this thread:
http://www.stevesnovasite.com/forums...ghlight=primer
Pretty informative
***Under Construction***
Build Update Link:
07-11-2006 #3
Full Blown G-Machiner
- Join Date
- Dec 2005
- Location
- Coolidge, GA
- Posts
- 988
wow it really does cost more to live on left coast!!
In my shop , based on what you stated, you'd be in the $10K-14K range! Considering no heavy metal work and not having to completly tear the car down and start over. And that would be a show quality job.
07-11-2006 #4
