View Full Version : Hydraulic clutch master install problem - HELP!
dhardison
07-03-2006, 04:53 AM
Yesterday I installed my TKO with a hydraulic T/O bearing and also installed the hydraulic master (NO slave actuator like with a T56, just a master cylinder). I bled the master, but the pedal has ABSOLUTELY NO pressure, I can push it down with one finger. I also noticed that when the cylinder is depressed, the T/O bearing does not move.
I disconnected the pressure line from the T/O bearing, held my finger over the end of the pressure line and depressed the pedal. I can baaaarely feel a little pressure against my finger, but expected fluid to blow past my finger. Only thing I can figure is that the master is bad.
Any thoughts??
Thanks!
derekf
07-03-2006, 07:30 AM
Can this master be bench-bled? (or is that what you already did?)
dhardison
07-03-2006, 08:48 AM
I didn't bench bleed it, you think that is necessary? It certainly can't hurt.
derekf
07-03-2006, 09:36 AM
If you're not getting any output, I'd try that before returning it and getting another.
