View Full Version : Power steering cooler
JEFFTATE
06-28-2006, 12:48 PM
I have been reading about the p/s cooler on David Pozzi's site. I'm confused about something. Which type of cooler is noisy and which type is more durable ? One is called a flat tube and the other is called a round tube. What's the difference? I think one design is like a small radiator or heater core with a flat bulkhead at each end. And the other is just round tubes with fins. Am I right ? I was going to use a small trans cooler in the p/s return line as a p/s cooler.
Samckitt
06-28-2006, 03:20 PM
Where is David Pozzi's site?
THanks
06-28-2006, 07:18 PM
I don't know if one is noisier than the other but the flat type is like a small radiator and according to Tom Lee, the flat type is more easily damaged by pump pulsations. We used a small trans cooler with round tubes. My wife ran the car at Streets Of Willow in 100 degree heat and the system stayed cool.
There is a little pump noise on my wife's car when parking but it's not bad. I've read that most remote reservoir systems are noiser than stock systems.
JEFFTATE
06-29-2006, 05:49 AM
Thanks David ! Your knowledge and experience is priceless. Thanks for sharing. Your website is great. You always seem to give a realistic view of how to get performance results without unecessary expense or flashy " wow " parts.
JEFFTATE
08-16-2006, 05:02 AM
I bought a transmission cooler to use as a power steering cooler.
Will it hold up ? I know that power steering pressures are higher than transmission pressures so will the increase in pressure and/ or flow cause a deterioration or leak in the trans cooler ?
Also , will trans cooler hose work to plumb the p/s cooler or should I use dedicated power steering cooler hose ?
( Obviously I'm putting on the return side )
08-16-2006, 07:07 PM
Trans cooler hose will work.
A trans cooler is good, it doesn't have to be a huge one, ours has four passes and is 3/4" thick.
I'm not interested in overly flashy parts, just getting the job done. I guess it comes from my early years, - not being able to afford flashy parts.
David
JEFFTATE
08-17-2006, 12:42 PM
Me too David. I want to drive this car a lot . I can't justify dumping huge quantities of money for parts that aren't 100 % necessary.
There is someone here on the site that has a slogan at the bottom of there posts that says something about huge wheels and huge brakes not impressing them ,but quick lap times do.
67LS1T56
08-19-2006, 11:06 AM
I have one in my car came with my LS1 engine as in WS6 Trans Am. It is inline with the upper radiator hose.
Steve1968LS2
08-19-2006, 11:17 AM
The guy who built my PS pump said I really won't need a cooler since he builds his to run cool from the start.
I was going to run that and an oil cooler, I sill might run the oil cooler depending on how my temps end up running.
I wonder where you could plumb in a guage to track PS fluid temps? I imagine you could use an oil or trans temp gauge.
