View Full Version : What the ???
69CamaroRacer
06-27-2006, 04:45 PM
This is the source of my latest frustration... if you look close you will see the hair line crack.. Just above the drip. What in the world causes this... All I know is that I was cruising down the road when all of a sudden tons of smoke started pouring out from under the car. When I parked it I saw tons of oil pouring out of the pan and 2 days latter when it finally stopped dripping this is what I found....
https://static1.pt-content.com/images/pt/2006/06/Picture003-1.jpg
Damn True
06-27-2006, 04:50 PM
Could be a couple things.
a) Bend radius is too tight.
b) The mfr got a lame batch of metal.
69CamaroRacer
06-27-2006, 04:54 PM
It is definately a first for me... and Milodon when I called them
indyjps
06-29-2006, 10:55 AM
youre either stuck pulling the engine and swapping the pan or drain the oil and weld it up. sucks though since you spent the $ on a nice pan, milodon will probably want it back to get a refund or replacement.
Matt@RFR
06-29-2006, 10:58 AM
youre either stuck pulling the engine and swapping the pan or drain the oil and weld it up. sucks though since you spent the $ on a nice pan, milodon will probably want it back to get a refund or replacement. Do NOT weld on an oil pan if it has ANY oil in it. It WILL catch on fire.
ZZ430
06-29-2006, 10:59 AM
I saw that once, the pickup was set too deep.
BonzoHansen
06-29-2006, 01:32 PM
I saw that once, the pickup was set too deep.Did it hit/rub the pan?
ZZ430
06-29-2006, 01:59 PM
Yeah, I should have said it bottomed on the pan.
Matt@RFR
06-29-2006, 02:04 PM
Who built the motor? Or more accurately, who installed the pump and pan?
