    Results 1 to 20 of 27
      Orlando
      20 pistons worth of 06 Z06 brakes on the way!
      My friend get me employee cost..only $1650!!
      That includes all 4 calipers (6 piston front, 4 piston rear)
      All 4 drilled rotors (14.1 front, 13.5 rear)
      and all 20 brake pads.
      I can't believe how cheap all that is, if it was Baers or Brembos, it would be 3K for the fronts alone!
      I should have them in a few days, I'll throw up some pics when I get them bolted up.
      The only problem with these is that not a lot of wheels fit them. They clear anything 18 or bigger diameter wise, but the face of the caliper hits the spokes of the wheels. The techs at HRE said I should have a few MM of clearance, we'll find out in a few days. I'm running ATX spindles, the bolt pattern for the calipers is supposed to be the same for all C5 and C6 brakes.
      Chris
      67 Camaro single turbo LSX/T56 -V2.0 underway
      06 AMG CLS55 2.9 Whipple, 5.6 forged Darton MID
      06 AMG E55 w 63 conversion 2.9 Whipple
      99 FRC Corvette pretty in pink
      connecticut
      keep us posted. and have they finnaly fix the mess where you could only get left side rotors?
      Feb 2006
      Elk Ridge, Utah
      Hit up Zak at Bozeforged for the wheels he can make them to fit anny setup you got
      69 Camaro
      W/D sub, Wilwood 13" brakes Bozeforged wheels 18X10 & 18X12,
      Lateral dynamics 3 link ( custom setup ) Dana 60
      lsX Twin Turbo, soon to come
      Viper T56 in place (Yay)
      Bought a running driving car so I can enjoy it before Im dead
      LD 3 Link Installed into ^^^^^ (Yay)
      Sep 2004
      How did he get them? I had my cousin at VW try to get me some at the discount price dealers sell to each other but they said you need a vin. Is there anyway to bypass this?
      1970 TA, 1963 Impala SS vert
      May 2002
      Northern California
      all you need is a part number. I think Yody listed them. He just sold his set up.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Orlando
      Needing a VIN # sounds like crap to me, anyone can order it. Mine had to come out of Michigan, but they're openly available.
      Chris
      Sep 2004
      I called the local parts department for these brakes and same thing they said I needed the VIN. I was going to get a vin off a corvette listed for sale I wonder if this would work or will I get in trouble.
      Sep 2004
      Kettering, OH
      Dealers use the VIN ploy when parts are scarce to make sure that they're taking care of true owners. It's a policy - not legal issue so I can't see how you can get in real trouble.
      1967 Firebird Convert, Fuel Injected 462 ci, TKO 600
      http://1967firebird.atwebpages.com
      May 2002
      Northern California
      Most dealers run vins cause it easier for them to look up parts and get the right parts ordered. Just tell them you don't have the car but just need the parts. Go in at 11:52 am or 4:45pm , you will get better service then.... Try another search cause the part numbers ARE out there. I 'll see what I can find too.
      direct link to gmparts direct http://www.gmpartsdirect.com/results...&partnumber=C6
      then links to helpfull threads: https://www.pro-touring.com/forum/sh...ad.php?t=12238
      https://www.pro-touring.com/forum/sh...ad.php?t=12911
      Nov 2004
      Norway
      Country Flag: Norway
      Quote Originally Posted by Whistler
      Hmmm, I assume you mean 8 brake pads? Otherwise, a pad for each piston is new to me...
      Thanks, Christian (@v8power.net)
      '77 Caprice
      '71 Chevelle Nomad - Perfect for roadtrips!
      Los Altos CA
      Quote Originally Posted by Chevy350
      nope theyre one pad for each piston
      I was wondering how you plan on mounting them in the rear, and what size of master. im still saving up for the fronts and trying to figure a way to mount them in the rear (i have c4 vette irs so im kinda skrewed) and i was hoping to be the first with theese suckers, guess not.
      Country Flag: Afghanistan
      Throw up some pictures when you are ready. I ordered the AFX stuff also. And right now I am thinking about brakes.
      Enfield, CT
      GM parts departments use the last 8 digits of the VIN to look up parts. They can tell what every part is on the car from that number - they don't have to ask you for options or anything.
      As a result, some of the newer parts guys don't know anything except what the computer tells them. They wouldn't know how to look up a part based on application.
      Orlando
      I'm using the master from an 01 Z28, and I'm going to try and use the brake booster from the same next week sometime.
      As for the rears, I'll wait until I get the brakes too see. I'll either modify an LS1 rear caliper bracket, modify an 06 Z06 caliper bracket, or make something.
      Chris
      Feb 2006
      Bakersfield, CA
      i think they may have wanted a vin to make sure you are getting the correct parts. most dealers have vin decoders in their parts cat. also if a part is on back orders gm dealers have an option to open a SPAC case on the part to help speed up the shipping, and for this they need a vin.....give me part numbers and ill quote you prices....
      as i am a parts manager at a gm dealer
      BAY AREA CA.
      Now $1650 is that before uncle sam's cut?
      Now its very true when it comes to backordered parts to have the vin but not for looking up parts for a Z06 because as far as I can see there is no options for brakes on a Z06 and the GM catalog separates all body styles and the Z06 is all by itself. Even if it wasn't a Z06 corvettes have about the least amount of options of any GM vehicle.
      Nov 2004
      Norway
      Quote Originally Posted by ilovefirstgens
      Interesting, please post pictures of these, or post a link if there's a site that has pictures. I just did a quickie-look at www.rockauto.com, but all I could find for the 2006 Z06 was rear pads, and they were pictures of the regular (two per side) pads with measurements.
      EDIT: Nevermind - found it!
      '77 Caprice
      Oswego il
      i work for GM i need to look into this. when i wrecked my silverado i was able to buy all the new sheet metal at emplyee prices, just had to pick it up @ the warehouse, no big deal we had a guy traveling back and forth from Mi every week helping with the program we were working.
      I would like to see some GM part numbers posted when you get the parts in your hands.
      Tim Knaebel
      For Sale-72 Nova SS, Blown and Injected Keith Black Hemi (7.38 @189 mph)
      69 Nova, 18's and 20's on AirRide with Turbo V-6 power.
      91 GMC Syclone #2373 of 2995 Turbo V-6, AWD.
      http://community.webshots.com/user/heminova
      May 2002
      Northern California
      pn's are on the link posted in reply #9. they work. there is a lot of good info on the other links too. Also check with Frank (Prodigy) he should have resources still.
