    Results 1 to 4 of 4
      Fabbing rear lower control arms on A body
      Was thinking about fabbing up some rear lower control arms on my bro's 69 chevelle, I'd planned on using 2x3 square tubing and notch the end for a piece of pipe, make the size of the pipe the size of bushing and get it pressed in
      Alta Loma,SoCal
      Yup, thats how they do it. I wouldnt use it cause i hate poly or rubber bushings.
      1965 Buick Skylark
      Nov 2003
      Paradise, Ca
      Your round tubing will have to be a much thicker wall than you need to end up with, because when you weld it to the rectangular tube, it's going to be out of round, probably in a big way. You'll have to bore it to your finish diameter after you've welded it.
      I'm with TurboLark though, figure out a way to use good rod ends!!
      -Matt
      Welders: The only people that think a co-worker catching on fire is funny.
      dennis68 Guest
      How about just buying a pair of 22" panhard rods from Coleman for 67.25/ea then you have plenty strong arms with rod ends at both ends.
