    Results 1 to 15 of 15
      Indianapolis, Indiana
      Thinking of 315/30-18 rear. Any thoughts?
      I am thinking about using a 315/30-18 rear tire on my 67' Firebird. I am wondering is this a common size? Also, do you guys/gals think the height will be too short? I think it is around 25 & 1/2" tall. Any thoughts or opinions would be appreciated. Also, just a little background I am considering 235/40 -18 for the front and the car will have a DSE mini-tub kit with leaf springs (3" drop).
      Ben Mowery
      67 Firebird -Powered by Pontiac w/ RAM AIR V.
      Central Florida
      I have that set up. I wish I could have found a 315/35/18. I think once my ride height is settled it will look OK. I went with the 315s out back and 265s up front. I think the spread between 335s and 265s is just too much in my opinion.
      These pictures are on a fresh suspension with no weight...sits way high. (GW UCA & LCA, QA1 CoilOvers, and DSE 3" Drop).
      http://s71.photobucket.com/albums/i1...aro%20Rolling/
      Katy,TX
      315/30/18
      There is a black 69 with white stripes on lateral g's home page that has 265/35/18's on the rear. They are within .1 of the height of the 315/30/18's. I think they look good. Also I noticed Bf goodrich drag radials 315/30 are a little taller at 25.6 inches.
      Linden Hill, NY
      I'd go with 305/30ZR18 Nitto DR's Way better traction
      Mountain View, CA
      ...unless you wish to turn corners.
      True T.
      My blog
      Jun 2002
      Oregon
      I'm going with 315/30/18 and a 245/40/18 on the front, unless I go against everything I've always said and squeeze a 335/30/18 back there!
      I have always said I think a 315 fits better than a 335 on a 67-8 camaro...but I also feel the 315 should be on at least an 11-11.5" wheel to help straighten the sidewalls. Right now I have a 315 on a 10" wheel and don't care for the look...
      As far as tire height goes, the 315/30/18 will be fine and a good match for the front, but it won't fill the wheel well opening completely unless your car is lowered a lot! My car is actually sitting this low right now for mockup, I can shoot you a pic if you would like...
      Tony
      Mountain View, CA
      Not a whole lot available in 315-35-17 is there?
      True T.
      My blog
      AWR68, yes please send me a pic. As far as lowering the back, I am going to run 3" drop springs from DSE.
      Ben Mowery
      NJ
      I have BFG GForce KD's in a 315/35-17
      South Ga..
      Quote Originally Posted by Patrick
      Yo Pat those wheels are sick!!The lip on the rear wheels are amazing!!PM or post who makes those wheels, I will get some made for my ride, I love the rolled lips...
      Nov 2002
      Georgetown,TX
      Quote Originally Posted by Damn True
      The selection isn't too bad,True. Goodyear,Michelin,BFG,and many others offer that sizing now.
      Mountain View, CA
      Goodyear yes. Though I hear the Eagle F1's tend to chunk with track use on heavier cars.
      BFG yes.
      Michi has a 285 and a 335 in the Pilot sports (they do have a 315 in the Pilot Sport comp "r" rated....sweet)
      True T.
      My blog
      Poulan GA
      [quote=Patrick] I went with the 315s out back and 265s up front. I think the spread between 335s and 265s is just too much in my opinion.
      Do the 265's scrub up front? how wide of a wheel are you using? Backspace? spacers? I'm trying to find some 315's but they are all to damn expensive.
      Central Florida
      I am running 18x11.5 in the Rear and 18x9 up front. The back spacing on the front is 5.75 b/s (I believe...I will have to find the build sheet.) Then I used a 1/4'' spacer....so 5.5bs should be OK. I will probably have a little bit of rub but I am using GW UCA and LCAs. And the tire is 265/35/18 which is 25.3 inches. A popular tire size on the Camaros is 245/40/18, which is 25.7 inches.
      Nov 2000
      O-town
      I'm looking for the 245/40/18 for the front, I have the 335/30/18 for the rear, rears are Pilot Sports, I plan on running a 18x11/12 rear
      18x8/8.5 for the front, need to get a good price on the fronts,
      Hey Patrick, photos look better than the Jeep
