    Results 1 to 6 of 6
      Jun 2006
      Caliper alternatives for B-car spindle swap on my 71 Z28?
      Title basically says it all. I am about to install the new tie-rod ends and spindles from a Caprice wagon. Will be capped off by a set of 1LE rotors.
      My main question is: What is the best low buck (read: junkyard) caliper option that may will work with this swap. Prefer a bolt on application at this stage as I have lots of other things to fab for this car and just want to get it on the road so I can enjoy it this summer.
      Thanks in advance for the help.
      Steve
      Rowlett Tx.
      From what I've been reading lately, the 72~87 1/2 ton truck caliper seems to be the hot ticket w/the 'budget' 1LE brake swaps.
      Dec 2003
      lost
      Why are you doing a "B" spindle swap on a second gen Camaro...the spindle is geometrically exactly the same. The only possible advantage is the larger rotor which will only marginally impact your braking performance.
      Jun 2006
      Quote Originally Posted by dennis68
      I'll plead ignorance. That is the first time I have ever heard that the second gen spindles are the same dimensionally as the B cars in question. Thanks for the info. As usual, ya just never know what you don't know!
      That said, any additional advatage in pad/rotor performance is something I'll take given that the car is a former hillclimb machine turned full time autocross car. I am now converting it back to street use for hopefull entry in next year's Cannonball/One Lap of America, which I did last year in another car.
      Scott, thanks for the suggestion on the calipers. I will check that out on Monday. Much appreciated.
      Steve
      Nov 2004
      Norway
      Country Flag: Norway
      The truck calipers are just a little wider, to be able to grab over the 1.25" truck discs, and won't help at all with the 1LE rotors (Or stock rotors for that matter, both are 1" thick). I believe the pistons in the truck calipers are the same size as the stock 2.gens, but I can't confirm this. I do know that the 2.gen calipers, and the 11" and 12" calipers are all the same size.
      Thanks, Christian (@v8power.net)
      '77 Caprice
      '71 Chevelle Nomad - Perfect for roadtrips!
      Aug 2005
      Hamilton, NJ
      Here is some homework I did on this swap. I have not 100% verified, but the part numbers jive with what others have reported doing in the past. It seems people often use larger 'height' D61 pads in this swap. I have the length & width measurements (from raybestos) but not height, so I cannot confirm that other than hearsay. Oddly, it appears the Camaro pads are wider by a hair.
      The 1-ton van/pickup calipers are physically wider than stock Camaro calipers. Some people have had trouble fitting the D61 pads into stock Camaro calipers. The van/pickup calipers were used in applications that used a wider rotor and a D52 (same as stock Camaro) pad. This physically wider caliper eliminates any fitment issues with D61 pads, and costs no more than Camaro stockers. Bolts up the same, but does require a slightly longer caliper bolt, which usually comes with the rebuilt calipers. It also appears the banjo bolt hole is larger on the truck calipers, which may necessitate a new hose (or hose end) & banjo bolt.
      PADS:
      D614A (D61) - 94 Caprice Classic 5.7L
      http://www.rockauto.com/ref/Raybesto...jpg&D614AD.jpg
      L: 7.19"
      W: .236"
      D52 - 77 Camaro
      http://www.rockauto.com/ref/Raybesto...2.jpg&D52D.jpg
      L: 7.22"
      W: .194"
      CALIPERS:
      76 G30 Van 7.4L
      A1 Cardone #184035/184036
      W/JB7, JD7 w/2 15/16” Piston
      http://www.rockauto.com/ref/Cardone/...tml?184035.jpg
      A1 Cardone #184006/184007
      77 Camaro
      http://www.rockauto.com/ref/Cardone/...tml?184006.jpg
      Quote Originally Posted by Ozman71
      Why Caprice specific tie rod ends? Camaro ones s/b correct from everything I have read.
      Scott from NJ.
      Vent Windows Forever! ...
