    Results 1 to 20 of 32
      LowBuckX now has C6 front rotors...
      Just put some 2005 Vette 12.8 x 1.26 rotors up front with some 1972 1/2 ton calipers.
      The brackets where fun to mod but worked out perfect.
      I made a 3/8 bracket that mounted to spindle and locates old bracket off that
      Lots of room in my rim but these rims are made for newer Suburban and Tahoes
      What do you think.
      Ive seen the pbdcbb and Mr Pozzis CBB and sorta combined then
      the pbd-cbb is stock calipers with c4 13 x 1.1 rotors or the 12x1.25 c4 rotors with the 72 calipers.
      If you care and want something clarified for you just ask.
      Just for your fast referance Rotors are $30 each Calipers are $16 each At Napa (used stock calipers as cores) Bolts from McMaster carr $6 So that is $98 for my front brakes
      Rear Discs set up was $260 (with master)
      St. Augustine, FL
      Dam thats cool. And so cheap.
      Andrew Petty
      Dublin, CA
      I remember when you were asking about options... this looks like a good setup. The brackets and spacers pushed out your rotors a good distance, but that makes the fitment of the late model rims easier I suppose. Never would have thought about the truck calipers; good find!
      I thought I got away cheap on my LS1 setup ($200ish), but you did much better. I tell you, cutting down the original disks for hubs saves a bundle.
      Jul 2003
      Anaheim Hills, CA
      Very cool.. would love to do a story on a low buck high-performance brake upgrade like that..
      Good work!
      1968 Track Rat Camaro:
      Thanks ..The combo of parts where mish mashed together from info I got from PDQ67 team Camaro, team Chevelle and other sites including alot of reading of old posts here at pt.com. But those set ups mostly all use the c4/c3 rotors but the 13"HD c4 rotors are $62 each. At $27 for the c5/c6 It just was a budget choice.
      I made a cardboard mock-up of the rotor (total height, thickness,diameter and caliper dimentions added) before I had my local NAPA order them.
      I also liked the curved fins in the C6 stock rotor Should stay fairly cool.
      Dublin, CA
      What did you end up going with for the rear?
      1980 TA rotors, 1980 Malibu calipers and soft hoses mounted on the Steeltech (ebay doug100) brackets.
      HILLBILLY HOLLYWOOD, TENNESSEE!!!
      Another upgrade for this setup is to look for Wilwood aluminum racing calipers in the single piston configuration that will replace the 1/2 ton iron single piston calipers used in this upgrade. This is a bolt on caliper that is typically used by the local crash em stock car guys running big Impalas etc. These calipers have a BUNCH of clamping power just like the iron calipers you are using. The Wilwoods save a bunch of unsprung weight.
      I have a new set and they are VERY light! Only drawback is that they are expensive new however a little looking should get a used pair cheap!
      Mike
      Remember, "Drive Fast, Turn Heads, Break Hearts!"
      www.musclecardeals.com
      Nov 2004
      Forney, TX
      Now that is an awesome "maximum bang-for minimum buck" upgrade. You don't happen to have any pics of the modified bracket before you installed the rotors, do you? I'm anxious to see how you modified your original bracket, and how (if at all) I can do the same on my late second gen spindles. I wonder if the G30 Van calipers that second genners use to allow a 12" 1LE rotor upgrade are the same as the '72 truck calipers?
      __________________________
      Boyd
      1972 P/T Style Chevy Short-bed - coming soon
      Specialty Auto Services
      Nov 2004
      Forney, TX
      I did a search, the G30 Van calipers are not the same as the 1/2 ton truck calipers. I was hoping they were because the 1-ton van calipers will bolt directly to a late second gen spindle with no mods. The largest rotor I've seen used with the Van calipers is the 3rd gen 12" 1LE rotors. I wonder if the Van calipers can fit the 12.8" C6 rotor? And why can the 1/2 ton truck calipers accept such a large rotor? Oh well, if it works, it works. Kudos to LowBuckX for "engineering" it. Got any pics of the bracket?
      Boyd
      Sep 2004
      Boyd
      I'm pretty sure that second gen spindles bring a whole different set of issues when trying to do this. The brake caliper bracket is cast as part of the spindle and not bolt on like our first gens. Right? I'm guessing you could cut the cast arms off and fab something, but I'm not sure.
      Not sure what the difference between van and truck calipers are but the truck caliper is used to handle the thickness of the rotor not the diameter. The calipers are not deep enough to use the entire surface of the rotor. I'm using truck calipers meant for a 1.25" think rotor. The C4-HD rotor is 1.1" thick. I used an old brake pad plate as a shim to narrow the opening. As you can see, there is 1/4 - 3/8 of an inch on the inside of the rotor that my pads are not touching.
      I made a completly custom bracket tyo hold the caliper, where ProTour72 made a bracket to move the original bracket outward. I really like this idea!
      Robb
      Dublin, CA
      The second gen spindle is an easy modification. Just cut off the ears and make an adapter bracket. Many people drill out the dust cover holes and retap for mounting the bracket. This is the same mod necessary to run Wilwood kits (except the direct bolt on GM-III's) or to use a C-5 conversion, nothing complicated.
      Brent
      Nov 2004
      Forney, TX
      Thanks EastCoast. Being a second gen guy, I didn't know the caliper bracket on a first gen was a seperate piece. If the truck caliper is used only for the width it allows, then I should be able to use a 1 ton van caliper. That is the reason second genners use it, it bolts to our spindle, it allows the use of a 3rd gen 12" 1LE rotor and D61 HD Police pads from a Caprice. The thickness of the package (I believe) is 1.125", so in theory- the 12.8" C6 rotor should work.
      **Edit, the package will not work. I didn't take in to account the obvious increase in diameter (duh) that requires the caliper to be moved further "away" from the spindle.
      Boyd
      Dublin, CA
      Boyd,
      Maybe I am missing something, but... the larger rotor interfers with the cast caliper mounting ears on the spindle, how is the van caliper then a bolt on? I did the LS1 conversion and that is the first thing I noted when mocking up the 12" rotors. I can not think of a way to mount larger rotors without cutting these ears off. How have you seen it done?
      Brent
      Sep 2004
      Boyd
      Sounds like you answered your own question... in this case, the increased diameter of the rotor is your issue. Moving the caliper outward is where the fabrication comes in. That likely opens up your choices of calipers since the brackets (i.e. mounting points) will be new anyway.
      It has been raining here for... well.... a f&%#*n long time. I will get some completed pics (if you're interested) once I can get the car out and clean it up.
      Robb
      Nov 2004
      Forney, TX
      Brent, you are correct. The van caliper does not allow a 12" rotor on a second gen spindle, but will bolt to a B-body 12" brake spindle. I oversimplified it because except for the mounting ears allowing a 12" rotor ( I know, that's THE critical difference ) , and some that have a different LBJ diameter, the B-body spindle is virtually identical to a late second gen spindle. This is a great lowbuck upgrade for the first gens, (LowBuckX needs to look into producing the brackets he made for this swap) but it will not work for second gens. I just saw the C6 rotors for less than a Benjamin and got too damn excited.
      Robb, I'd like to see pics when you can get them.
      Boyd
      took it for a long ride today and the diferance is night and day. Stops 100% better. Im happy
      Did you originallly start with drum brake Nova spindles or disc Nova brake spindles when you began this conversion?
      Mike
      Sorry for the long wait for the answer. I started with factory discs
