View Full Version : Stance
rockdogz
06-04-2006, 09:23 PM
Lowered the front as far as it will go. I have some 1" lowering blocks for the rear - think I should use them?
aonghus
06-04-2006, 09:46 PM
give em a shot and see if you like it.
I personally like it when there is maybe 1/2" gap to 1/2" no gap between the tire and the wheelwell in the rear, but maybe it'll ride terrible or scrape something?
no point in doin it if you cant pull in a driveway or drive over a speedbump.
lookin good with the glass in there!
keep it up, you're getting me motivated to go work on mine!
trapin
06-05-2006, 02:43 AM
I don't know...in the first and third pictures it looks like it needs to go down some, but then it looks perfect in the 2nd picture. Hmmm.....what size wheels are those?
vanzuuk1
06-05-2006, 03:13 AM
Rock, you could go lower and it would look great, assuming its driveable.
I had the nose of my car real low, it looked great. Then I decided to follow the common theory of having the lower control arm pivot about a half inch higher than the balljoint center and now my car looks too high.
I may ignore the math for now and just drop it to where it looks cool again.
rockdogz
06-05-2006, 05:57 AM
Yeah, I see what you mean... They are 245/35 on 17x8 and 315/35 on 17x11.
trapin
06-05-2006, 06:58 AM
1" block should do the trick, Tom. I just looked at some other shots on your site. By the way, where'd you get that sweet fuel cap?
BRIAN
06-05-2006, 07:15 AM
Stance looks good but the rear tire looks stretched on the rim. In my opinion it would look better with a little more sidewall bulge and height to the rear tire. The 67-68'2 are hard to get right do to the shape of the inner wheelwell which does not allow the car to sit that low as a 69 does. Like the rims.
6'9"Witha69
06-05-2006, 07:30 AM
I say try the block
rockdogz
06-05-2006, 07:48 AM
I would love to find a 315/45 tire but I just don't think anyone makes them
rockdogz
06-05-2006, 07:50 AM
It's a Goodridge motorcycle cap. I got the idea from Mecom Racer. It took a custom tailpanel, plus we moved it up since the lock was shaved. I'm happy with the way that turned out - was trying to get in a few subtle changes to make it unique.
colt zantop
06-05-2006, 04:22 PM
very nice! I agree...2nd pic looks perfect but other 2 pics make it look like it needs to come down just a tad. I want to lower my rear about an inch or 2 also but I already rub sometimes... if you rub now..dont even bother...it looks damn good the way it is!!
67LSRS
06-05-2006, 06:42 PM
Great looking car, I think the rear could come down a little more if it does not render it undriveable. IF its to close leave it alone. And again nice lookin car. If you dont mind me asking what springs are you using in that front and rear?
rockdogz
06-05-2006, 07:17 PM
Running the Chassisworks front suspension with their Varishock units - 600lb springs. Rears are DSE 3" drop leafs.
rockdogz
06-05-2006, 07:18 PM
Dang, I tried to put in the 1" lowering blocks and the U-bolts were too short!
trapin
06-06-2006, 05:38 AM
That's an easy fix. I had some really nice galvanized ones that I got with my Southside Machine Lift Bars, they had a ton of thread on them. I accidentally included them with my Hotchkis 2" drop leafs that I sold to a guy on the west side of the state. I'm still kickin' myself over that.
67LSRS
06-06-2006, 05:38 PM
Thanks ROCKDOGZ
those DSE three inch look good, I went with the two inch, not installed yet and looks like I should have got the three.
patriot68
06-06-2006, 06:28 PM
hey rockdogz how wide is your rear end..how much clearance do you have between the rear fender lip and the tire??
that first question sounds kinda gay hugh??:pat:
rockdogz
06-06-2006, 09:16 PM
Not much clearance between the lip and the tire - maybe 1/4 to 1/2" at the top. I think the rear end was 52.25" from backing plate to backing plate, but I'd have to measure it when I'm under there again because it was just too long ago to remember...
rockdogz
06-08-2006, 01:12 AM
Ok, well after 3 hours in the O.R. I have the lowering blocks installed. Isn't it harder to work at night when you're trying to be quiet and not wake the neighborhood? The U-bolts that Summit had which were the correct length were 9/16" instead of 1/2", so they didn't want to slip into place as easily... I sure like the beefy qualities of the new U-bolts though.
Here's a quick pic, although I think there will be some more settling/adjustment happening. I can't go any lower now without ditching the Caltracs, since they are now even with the bottom of the rim...
I like it though, and now I hope it drives ok without issues.
Mr.VENGEANCE
06-08-2006, 06:05 AM
did the same thing on mine.. i love the ride quality too..
same exact drop also.
rockdogz
06-08-2006, 09:04 PM
Ok, this is it - as low as it will go with the current suspension and 1" blocks. I think the leafs will still settle some more.
Man I have like 2" clearance under my exhaust and it really scrapes coming out of the driveway with the dang drainage gutter... Need some ramps I guess.
Jims78elky
06-09-2006, 02:10 AM
Tom,
Its looks killer! Your neighbors are loving you everytime you
start that bad boy up! :ssst: lol..J/k.
Is it time too start on the interior? Any plans or idea's?
And are your rims clear coated? you worried about them
getting "fogged" up eventually? Iam just a big chrome/polish
dude i guess.
The 68 is just awesome looking!
Keep up the great work!
rockdogz
06-09-2006, 10:21 AM
Tom,
dude i guess.
Keep up the great work! Thanks Jim - Sure they love it, why wouldn't they - I do! lol - they're cool. I'm trying to get all the wiring done inside so I can get the interior done. Wheels aren't cleared, hadn't thought they would fog up, time will tell.
Jims78elky
06-10-2006, 01:47 AM
Tom,
Yeah don't worry about the rims,i remember back in the
late 70's (ouch.. old man on deck lol) I had a new set of
unpolished centerlines,you know "skinny's in front "fatty"
out back,and they..even though i washed the car daily
practically,just turned "foggy" looking,a haze that i could
not get to come off with a handfull of cleaners or elbow
grease...:nopity:
it very well could have been the cleaner i was using,too
strong,or allot of brake dust build up,i could have had them
polished,but i was very new into the hobby,i think now the
wheel companies are using far better materials,and the
quality is top notch...*Not bashing centerline here* they
have always had a good product line to offer.
Was just a weird experience i had..After all it was in the
late 70's
:kiss: +:Alchy: +:smoke: lol...
"Frampton Come's Alive"
I always wanted to say that..lol.
CliffS
06-10-2006, 10:24 AM
Killer car Tom! I follow your projest for quite a while now. Any pics from the caltracs/ ground clearance?
