    Results 1 to 19 of 19
      northern california
      65 chevelle wheels how big
      can any one please tell me what the best wheel and tire combo is for my 65 whithout tubbing.hotchkis tvs,whith globalwest upper a arms.thanks
      Nov 2002
      Georgetown,TX
      What diameter do you want to run?
      livermore ca
      Quote Originally Posted by USAZR1
      im looking to run 17-9.5 in the back with a 275/40/17 and a 17-8 in the front with a 225-40? what do u think its for a 65 chevelle
      livermore ca
      i was thinking about the coys c-5 www.coyswheel.com remeber im on a budget so they might not be the best rims but they have a nice lip in a 18year old price range
      Nov 2002
      Georgetown,TX
      Quote Originally Posted by lt1chevelle
      Here's what a friend of mine is running on his 65 El Camino. The info came off the Wheel & Tire Database (page 3) on Team Chevelle.
      Car: 1965 El Camino
      Wheel Make: Fikse
      Wheel Model: Profil 5S
      Front Size: 17x8
      Front Backspace: 4.75"
      Rear Size: 17x9.5
      Rear Backspace: 5.625"
      Front Tire Size: P245/45ZR17 Nitto 555
      Rear Tire Size: P285/40ZR17 Nitto 555
      Suspension mods: GW Tubular upper and lower front control arms with QA1 12-way adjustable coil overs and OEM GM front sway bar. Edelbrock adjustable upper and Curytrac lower rear control arms with QA1 12-way adjustable shocks and OEM GM rear sway bar. Hydratech Hydroboost power brake unit with 1970 Corvette master cylinder. Wilwood 12.9" front rotors and 6-piston calipers, Wilwood 12.2" rear rotors and 4-piston calipers. Richmond 7021626JB 6-speed (0.81:1 OD ratio) with a 3.07 12-bolt posi rear and superior axles.
      northern california
      i would like to run a 17.is a17x8 the widest with out a mini tub on a 65 chevelle?
      Nov 2002
      Georgetown,TX
      Did you read my previous post? You can run a 17x9.5 with 5.5" backspacing and a 275/40 tire on a 65 Chevelle. A 285 tire will fit snugly with 5 5/8" backspace. Just measure to make sure the car's body is centered on the frame.
      northern california
      yes i did read your post .i have a chevelle not a el camino do u know if that will work on chevelle.do el caminos and chevelle have the same space in the back wheel area?
      Nov 2002
      Georgetown,TX
      The 68-72 Chevelles and El Caminos have the same space but I'm not 100% sure about the earlier cars. My guess is they are the same,too. Never hurts to measure your car first,though.
      northern california
      what about 18
      Nov 2002
      Georgetown,TX
      Quote Originally Posted by 65chevelleboys
      what about 18
      Yep.
      livermore ca
      Car: 1965 El Camino
      Wheel Make: Fikse
      Front Size: 17x8
      Rear Size: 17x9.5
      is his car stock hight? i was going to lower mine 2-3 do u think it will still work? or will i prolly need a smaller sidewall hight? also it will be a 17-8 not 9.5 and the rims have 4-1/2 back spacing
      Nov 2002
      Georgetown,TX
      Dave's Elky is lowered probably 2". You should be fine but 5" backspace would be a little better choice on those 8" rear wheels. 64-65's like a little more BS than the later cars.
      Jul 2002
      Mesquite, TX
      Can't stress enough that before sending the cash to buy a set of expensive spiffy wheels in a custom offset that you really need to measure to determine exactly what YOUR car needs so far as wheels go. Tolerances weren't all that tight 40 years ago when your car was new, and any manner of things may have changed the dimensions of your wheelwells since then.
      So cal
      Quote Originally Posted by derekf
      Amen to this advice! My neighbor found this out the hard way!
      I know a few yrs. ago I paid a guy 20 bucks to measure my NOVA for my 17's and they look and fit nice and tucked no prob's.
      I suggested my neighbor do the same but Noooooo he was a wheel specialist! ....... the look on his face when they didnt fit was priceless and wow did the cussing start,I queitly went home!
      72 Nova
      May 2010
      I could only get 8in on my 64. But mine is lowered
      Jun 2010
      Arroyo Grande, Ca
      Quote Originally Posted by lt1chevelle View Post
      I have Coys C5's on my 66 elcamino 17 frnt 18 rears but just added 13" rotors so now when i need to inflate my tire I have to remove the wheel due to the air location is right in line with the rotor....they did there home work on that design....so beware
      Oct 2010
      kansas city Missouri
      i have a set of ttII's polished aluminum 17 X 8 @ 4.75 bs (X4) cheap, also 17 X9.5 @5.5 bs (X2) if interested PM me
      with /good tread bfgs KDWs and potenza re-11's
      i went with rushforth Xrated 18" and will have to e-bay them anyway.
      Meassure carefully! Seriously doubt that you can get 9,5 inch with 275 in the rear lowered or not. My wheelwells are modifyed and I barely get 265's in. Maybee 275 but i got a independent rear suspension that barely moves the wheel sideways at all. You have to consider more sideways movement under suspensin travel on a orginal rear axel. At least 1/8 inch,probably a little more on both sides of the tire.
