View Full Version : Front hoses
Art Tirrell
06-01-2006, 02:17 AM
I am installing C4 calipers on the front of my 64 Buick Special with 13" rotors. What should I use for hoses? Thanks
Steve68
06-01-2006, 02:54 AM
braided or rubber, I bought braided,
Art Tirrell
06-01-2006, 03:47 AM
Rubber is fine for this application.
Steve68
06-01-2006, 04:59 AM
It comes from GM that way, I had some extra money so I bought Goodrich lines from Baer, and they were too much,
Art Tirrell
06-01-2006, 05:49 AM
Were your hoses custom or do you know of a specific hose that will fit?
Steve68
06-01-2006, 06:00 AM
I think I bought them for a PBR caliper
shep
06-01-2006, 09:03 PM
you might try lines for a 69 camaro I think that is what has been used for the other A-body conversions.
Art Tirrell
06-02-2006, 02:16 AM
Thanks to all.
barno68
06-02-2006, 11:17 AM
I ordered mine from Summit using Earl's Performance Pluming parts. They make a generic braided hose with 3AN swivel female on one end and a 10mm banjo on the other for $18. The other parts needed: 10mm 1.0 banjo bolt (.425" height) and a tubing adapter (3AN male to 3/8" female inverted flare). Total cost for both sides was around $55 and the hoses meet DOT requirements. This was for a PBR caliper, hope that helps.
Art Tirrell
06-03-2006, 04:02 AM
Thanks, barno.
brickyard69
06-03-2006, 04:13 AM
Try Noel at Touring Classics or Classic Tube.
Either one knows brakes!
Art Tirrell
06-13-2006, 02:11 AM
I received my new hoses last night and they fit great. I ended up with stock 91 Vette hoses. Now I am trying to find the 10mm banjo bolt.
Steve68
06-13-2006, 02:39 AM
Dealer! and get factory brass crush washer, aftermarket is junk,
barno68
06-13-2006, 08:36 AM
Why do you say that Steve? I have some 10mm 1.5 from Earls, but have not torqued them yet as my hoses are back ordered. Have you had leaking problems before?
Brent
Steve68
06-13-2006, 06:57 PM
Well, maybe not Earl's but I got some new/reman calipers for a friends 00 Blazer, and for the life of me couldn't get the lines to quit leaking, hunt the old ones put them on and the flooding was over, buddy own a shop he says I never use the sheeott washer, just a little FYI,
Just think, just like Jason(Fuel) new paint and brake fluid, it don't mix, includes skin!!
BonzoHansen
06-14-2006, 09:34 AM
I'm not sure why, Steve, but the problem you described I have seen many times. We would change hoses or calipers on a car and they would leak until we used the old brass washers. Then problem solved. I can't figure out why the new washers don't always properly conform (that is my guess as to what is happening). I mean brass is pretty soft.
Joe_Rocket
06-16-2006, 11:01 PM
The braided lines themselves are fine, though not nearly as flexible. You can't make tight radius bends with those.
Yeah, I do not care for the aftermarket stainless banjos and bolts. I really think the bolts are a little short. There's not many threads showing once you put it through the banjo with two washers. I had to really crank those suckers down to get a seal. I'm sure if I go any tighter I'll strip the threads in my new PBR's. I just don't feel comfortable with the setup.
If I can find some stock PBR Caliper bolts, I'd like to compare the lengths with those of the stainless bolts in the braided line kit. I may also switch back to rubber hoses with the grooved brass ends. I think those groves make a big difference in sealing.
