Results 1 to 16 of 16
05-31-2006 #1
Door poppers - modifying door latch
I'm having fun getting the door poppers to work with the stock latches on my '68. There seem to be two limitations with the door popper solenoid that I'm running into:
-they can't have a load on them - cable must be loose
-they only pull about 3/4"
So I think I may need to make some modifications to the door latch, and wanted to get some feedback.
In my pic of the door latch here, when you pull up on the door handle inside the car, it pulls in the direction of A. The lever in turn causes the part B to go down, and pushes on the lever C. However, this takes too much motion - much more than 3/4" to occur. Plus, you can't pre-load the cable on the solenoid and get it close to releasing the latch, because of the first limitation.
So my thought is to drill at D and put a pin in there to limit the upward travel of the lever C. This would make B then only have to travel a very small distance - say 1/2" - to release the latch. What do you think?
I know that the other way to trip the latch - the lever you push when pushing in the button on the outside of the door - takes less effort, but this lever travels 90 degrees opposite of the direction of A and I can't see how the solenoid could be mounted to make that work.
06-01-2006 #2do the math and mount the cable (perferrably rod) from the solenoid inbetween the "A" cable and the pivot of the arm.
68 Camaro - never to be finished
06 Silverado - Forged 370, L92 Heads, big cam, 4l80e ect. eventual donor for the above
http://www.youtube.com/watch?v=KmB2y7uX38I
06-01-2006 #3There is too much travel - the solenoid can only pull about 3/4".
Originally Posted by Camaro Zach
06-01-2006 #4
