View Full Version : Fuel filler misaligned
navyflyer72
05-31-2006, 01:26 PM
I have a 67 Camaro and a narrowed stainless fuel tank from DS&E, I noticed recently a BAD leak when filling up. After inspecting through the access area behine the license plate I discovered that the rubber hose that attaches the filler tube to the extension tube on the tank had to make a severe bend forward to attach to the tank and was being pulled off of the tank extension causing the leak. I don't think the tank can be moved back any further to align the tank extension with the filler neck, anyone else run into this problem, any ideas on a solution? I was thinking maybe a more flexible connecting hose, but not sure what to use that will withstand the fuel... Any ideas would be helpful.
-George
icemanrd19
01-04-2015, 12:24 PM
I'm wondering the same thing now. Im bairly off but still off.
camrat68
01-04-2015, 01:31 PM
Shorten up your filler neck on the gas cap end rather than the tank end and run a longer hose rather than the stock coupler hoses.
Something like these...
http://www.speedwaymotors.com/Installation-Hose-Kit-for-617-9040-8-Inch-Length,51119.html
Or an angled hose...
http://www.lmctruck.com/icatalog/cd/full.aspx?Page=108
-Jim
icemanrd19
01-04-2015, 04:10 PM
I opened up the hole alittle more and used a 45 degree hose. It bolts up fine now. Well sorta. I need another hose because i cut it slightly too short on one end. lol
renegade6
01-04-2015, 05:42 PM
Look for marine filler hose.
Gratefuldiver
01-15-2015, 08:49 PM
I got some hose from these guys. You can buy it by the inch or 3' sections in just about every dia
http://www.fillernecksupply.com/servlet/the-Fuel-Filler-Hose-cln-2%22-or-51mm-Diameter-cln-Sold-Per-Inch/Categories
