    Results 1 to 5 of 5
      Oct 2005
      Graves County, Ky
      Door glass removal
      Hey all,
      I'm trying to get the door glass out of my 69 Camaro. I have no idea what I need to do to get the glass out. I have already unbolted the glass from the regulator, but I have no further ideas from here.
      Some help would be much appreciated.
      England
      the is a small bolt that goes through the glass on a 67 near the door handle check that
      Portland, OR
      There's a few steps, but here's the bullet points:
      -Rmove the up stops from the rear guide and front lower sash channel
      -Loosen the stabilizers at the top of the door frame
      -Loosen the upper retaining bolts on the front & rear window guides
      -Remove the lower sash-channel cam attaching nuts (PS - the studs are attached at the bottom of the window so be careful pushing these out of the channel. hold the bottom of the glass when you do this).
      Lift the window thru the top of the door - you may have to slide it a little forward and tilt the glass in toward the car to get the rollers to clear the sill.
      Dave
      69 Camaro
      "Talk is cheap because supply exceeds demand."
      Oct 2005
      Graves County, Ky
      Thanks for the replies,
      I will do what you guys said and see what happens.
      Jan 2003
      Arizona
      One more step. Don't throw anything out until after you have all of your replacement hardware. Been there, done that.
      ________________
      Steve Chryssos
