    Results 1 to 4 of 4
      Apr 2003
      chbg, pa
      can anyone help on a hyrdaboost topic right now?
      I am having a problem with the car running. i am tryingg to back it out of the shop and it stops without me even putting a foot on the pedal , when i start the car it pulls the brakes down right away and wont allow me to move .
      can someone help ? I am going to the dyno first thing in the am and it wont move !!!
      Central Florida
      I had a similar problem on my 4X4. I dont have Hydraboost--I have a huge double diaphragm booster. The brake pedal would get sucked down and apply the brakes. I called the manufacturer and it turned out I did not hook up the pedal return spring. Something simple but overlooked. When the spring was hooked up the brakes worked fine. Hopefully, yours is an easy fix too. BTW-- do you really need brakes on the dyno.
      Jul 2002
      Muskegon, MI
      Is this the first time you have tried the car with the Hydraboost? Mine did the same thing but for only a few times. Did you follow the start up/break in procedure? Just get a couple miles on it and you will be in love!! Good luck tomorrow with the dyno.
      Adam_______Offical Car Name "ILLUSION"
      383 Stroker, Stock cast heads, T-56 tranny, 4.11 gears, 2002 T/A dash, 4th gen interior including seatbelts, power lumbar seats, 18" Budnik Wheels, Hydraboost, QA1 shocks, DC Controller, Power steering conversion, fuel cell, unique exhaust set up........
      ILLUSION Website-----------Old Website--------------My Car on Lateral-g.net----------- Need something designed?-AdFabDesign
      May 2002
      Northern California
      we had a similar problem. check your pedal and booster rod. one may be too far out.
      Also did you change your pedal rod to pedal lever angle at all?
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
