View Full Version : Backspace Tool
Scarface
05-12-2006, 06:16 AM
Has anyone used the wheelrite from Percy's High Performance? I am looking to get a new set of wheels from Budnik and I need the backspacing to be right on the money with the size tire I am wanting to run. I am not real good with just measuring the backspacing with a tape measure so I was thinking about maybe getting this tool
Brent
astroracer
05-12-2006, 06:38 AM
Brent,
There is no reason to spend a lot of money on a tool you will use one time when the same job can be done with a little research and a 5 dollar tape measure...
Do a search here on measuring backspacing. I know I have listed a number of sites like Alston or Chassis Engineering that provide worksheets to do exactly what you need to do, for free....
Once you've done this a few times it gets real easy and you would never even consider buying a "tool" to do the job...
Just trying to save you some money...
If you can't find anything let me know and I'll repost the sites.
Mark
Scarface
05-12-2006, 08:25 AM
Brent,
Mark
Thanks I am going to try and do some measuring with the angle iron and see how that goes. Do you happen to have that link handy
Thanks allot for the help (I love this place)
astroracer
05-12-2006, 09:07 AM
This site has everything you need, but, it could be a little clearer...
http://www.rsracing.com/tech-wheel.html
This should help with your project... It is an axle worksheet but it makes you do all of the needed dimensions for figuring backspacing/offset also. Good stuff.
http://www.cachassisworks.com/worksheets/fab9_instructions.pdf
Holler if you have any more questions.
Mark
indyjps
05-14-2006, 07:38 AM
2 pcs of flat stock one drilled to accomodate 2 lug nuts is all you need if you dont trust your tape measure. slot the second pc for a bolt and run it perpendicular for exact measurements.
Scarface
05-14-2006, 11:14 AM
Thanks everyone for the help I took some angle aluminum and drilled it then bolted it up to the hub the worked out real nice. Looks like I have allot more room than I had thought so now it is time to order my Budnik's
Going to try and get my wheels ordered next week (6 to 8 week build time)
Thanks again
62wagon
05-15-2006, 05:09 AM
Brent.
Brent - Myself and a friend went together and bought one. I see you have come up with your sizes, but to answer your question and maybe some others it works pretty well. It has a bunch of measurement possibilites and it pretty simple. The only thing strange is they tell you to lay a piece of wire across your desired tire and attach that to the tool. Seems to me you wouldn't have the right tire until you have come up with the right wheel. A little odd but a nice little tool. If anyone is looking at buying one, I would recommend it.
Mark
MBD
05-15-2006, 07:37 PM
Mark
The site above has an image of a wheel that shows the backspacing measured from the hub mounting surface to the extreme outer edge of the rim. Is this information correct or is it supposed to be measured to the inside lip of the mounting flange?
astroracer
05-16-2006, 03:03 AM
Backspacing is measured over the "entire" width of the wheel. The diagram is correct. If you lay the wheel face down and lay a straightedge across the back side of the wheel the backspacing is measured from the mounting face to the straightedge.
Mark
redss86
05-16-2006, 04:20 AM
The only thing strange is they tell you to lay a piece of wire across your desired tire and attach that to the tool. Seems to me you wouldn't have the right tire until you have come up with the right wheel. Mark
A lot of people say to buy the tire, then get the rim that the tire man. recommends. Plus most companies will accept a tire return but not as many rim returns. Especially if it is a custom bs.
bretcopsey
05-16-2006, 05:18 AM
Percy's is coming out with a plastic verwion of the wheelrite for $89. Still not as cheap as the angle iron method, but possibly easier to work with?
I have two projects to measure for wheels, and I'm thinking of buying this tool.
http://www.percyshp.com/producthomewheelrite.html
syborg tt
05-16-2006, 08:12 PM
i have the version from wheel tech and it was worth it's weight in gold. We were able to mount various wheels and turn the wheel back and forth and check clearence on the inner fender. We were also able to move the tire through suspension travel to look for possible conflicts.
It's amazing how many friends you have one you have one of these in your toolbox.
Tiger
09-05-2006, 04:43 AM
Hi,
the plastic wheelrite is only $69.99 from jegs
#760-01201.
IO'm thinkin about getting one.
Tiger
09-06-2006, 12:15 PM
I ordered one from jegs today, I'll have it in a month or so
72Z/28
09-09-2006, 02:27 PM
I got a link here that illustrates all the measurements you need , backspacing, offset, etc..I hope that helps.. GOOD LUCK
http://www.customtacos.com/tech/index.php?article=40
GBodyGMachine
09-09-2006, 03:12 PM
I have been looking for one of these tools for a month.
cadpro
09-09-2006, 04:45 PM
So, what kind of Budniks are you getting? What's the price?
