    Results 1 to 20 of 26
      Scottsdale AZ
      Can't find 9.5" wheels for a 69 Camaro
      It seems like a good combination on a non-tubbed 1969 Camaro is the 17X9.5" rear with a 275 tire.
      Other than Torque Thrust II, I seem to only be able to find wheels in 9" or 10".
      I do not think I can run the 10".
      Is there a big difference in the 9 vs. 9.5?
      I want to run the widest tire I can with the car sitting down 2".
      Any ideas/suggestions?
      Also, does an 18" look a lot better?
      Eastern Virginia
      I have 9.5" rear wheels on the Monte. They are from Centerline. Check with them.
      Scot
      Scot
      86 Monte SS
      Nov 2004
      dayton ohio
      go to newstalgia wheels (a sponser here) and check out vintage wheel works
      mo
      check out budnik wheels,they can make.and i pretty sure a 10 inch wheel will go a 69 camaro.i know they will my 69 in high school had 10 inch wheels,and a 285/35/18 should fit a 10
      May 2006
      http://www.billetspecialties.com/ is where I got mine. Nice wheels, and they will build to your specs. Coincidentally, I have a set for sale, 18x9.5, 5.5" BS...
      Sep 2004
      Metamora, Illinois
      I have 9.5" Budniks on mine.
      Dec 2002
      Wichita Falls TX
      Newstalgia is where I got my 9.5 inch Street Stars and for a good price to boot.
      Scott
      Scottsdale AZ
      atwot
      pm sent
      Jul 2002
      Muskegon, MI
      9.5 Budniks on mine too. 18"
      Adam_______Offical Car Name "ILLUSION"
      383 Stroker, Stock cast heads, T-56 tranny, 4.11 gears, 2002 T/A dash, 4th gen interior including seatbelts, power lumbar seats, 18" Budnik Wheels, Hydraboost, QA1 shocks, DC Controller, Power steering conversion, fuel cell, unique exhaust set up........
      ILLUSION Website-----------Old Website--------------My Car on Lateral-g.net----------- Need something designed?-AdFabDesign
      Scottsdale AZ
      Will 18" 9.5" fit a stock wheel well?
      I am ok with rolling/trimming the lip.
      Jul 2002
      Muskegon, MI
      Quote Originally Posted by brickyard69
      Yes thats exactly what I did and I am sure my car is a lot lower than yours will be. All I did was roll the rear lips. I havent rolled the front lips at all yet.
      Jul 2002
      Muskegon, MI
      This is the specific information right off my site.
      Budnik Famosa 18" Wheels
      Front 18x8-----Rear 18x9.5
      5" BS----------5.5"BS
      Nitto 555R Extreme Tires
      Front 235/40-18---- Rear 275/40-18
      Houston, Tx
      FYI, I have a set of Billet specialties 18x10 with 295/35/18 in a factory 69 wheel well.....lips are rolled, but no tubs and NO rubbing!!!
      Drew
      Drew H.
      Scottsdale AZ
      Drewhelm:
      What is the backspace on those 10"?
      Adam:
      Thanks! I have looked at your site MANY times.
      Scottsdale AZ
      Will 10" work if 9.5 is not available?
      Also, I think the Nova 8.5" rearend is wider than a stock 69 Camaro rear. Does anyone know the standard length of a stock 69 10 bolt rear?
      Central Florida
      Call Zach at BOZE Wheels. They built my wheels: timely and professional-- and they are site sponsor. Look under the ZE Forged section 3pc. They offer wheels in 9.5" widths.
      http://www.bozeforged.com/wheels.html
      Oswego il
      the nova 8.5 is slightly wider, i used to run one before i had my 9" cut down. now the 9" i have isnt the same as the original camaro rear once the brakes were installed.
      i urge everyone to take their own measurements before spending $ on wheels. once the 1/4's have been replaced once or twice things may change even more.
      Feb 2006
      Elk Ridge, Utah
      I had 10" in the rear of my last 69 camaro
      You may need to do a little work back there to get them to fit
      But not minitubs
      Man ur still looking furr wheels eh?
      Linden Hill, NY
      You still need wheels?
      As I have a set of HRE 17's for sale
      9.5 fronts
      10.5 or 11 rears (can't remember)
      Kevin
      [email protected]
      Scottsdale AZ
      Yes, I still need wheels.
      I really like those, but the rears are too wide.
      Steve
