View Full Version : Coilover 4Link in a 1992 GMC Typhoon - Need Help
crazykaese
05-02-2006, 05:45 AM
Is there enough room in front of the gas tank to fit the support crossbar that the top of the shocks and the panhard bar attach to or do I need to install a different gas tank? It's tight up in there and I was wondering if any of you have successfully done this install on a 1st gen (1982-1994) S-series Blazer. This problem is a non-issue on pickups since the gas tank is in a totally different location. The truck is up on the installer's lift and I need help real quick. The 4link kit I am trying to install is off of a wrecked Typhoon but I can't get in touch with the prior owner. It was made by PEP.
BelgianProtourer
05-03-2006, 01:16 AM
Hello, I'm also a Typhoon owner, you should check out www.syty.net (http://www.syty.net), I think the 4link has been done before. Hope this helps.
Greets,
Arlo
