View Full Version : New Member in NW Houston
DReid
04-26-2006, 07:06 PM
Hello everyone - I've checked out the site before but spent most of my time on Camaros.net. I'm almost done, it that ever really happens, with my 67 Camaro. - My version of a G - Machine
I've been to the Spring Cypress street meet a couple of times on Saturday and plan on being there most Saturdays this summer. Ask me if you don't know. 350 cars and it's free!!!
Below is my build sheet - I just cut and pasted anyway I'm trying to finish up a console/trunk and headliner and should be ready for summer. Have any questions about anything I've done? Fire away.
I love this site and what I see so I know I'll be asking my own.
383 Stroker
Edelbrock Air Gap port & polish match with heads
Barry Grant Speed Demon 750 electric choke VS
Vintage Air Frontrunner Serpentine belt drive system
Edlebrock Performer Aluminum heads 2.02 Full street port/polish
Keith Black 10.3 – Pistions
Comp Cam 280H Duration at .050 – 231
Hardened comp cams push rods
All ARP bolts
Exhaust
Flowtech hot jet coated 1 5/8 inch full length headers
3 inch mandrell bent with Flowmaster 40 series
Transmission
Tremec TKO 500
Centerforce Dual friction clutch/pressure plate
Centerforce bell housing
Rear End
8.5 inch ten bolt posi built by Pyle Brothers
Eaton posi 3.55 gear
Superior Axels
Suspension
Global West tubular upper & lower control arms with del a lum bushings
QA1 single adjust coil over shocks
Hotchkiss rear lowering (1 ½ inch) leaf springs
Poly urethane bushings all around including motor and transmission mounts
2 inch Superior drop spindles
Steering
Detroit Speed & Engineering quick ratio power steering gearbox
Tilt Column
Cooling
Be cool polished aluminum radiator
Spall 14 inch electric fan
Stewart high flow T-Stat
AC/Heat
Vintage air Gen II heat and cool
Brakes
Baer Brakes – Front Track system 13 inch slotted/cross drilled, zinc washed rotor, 4 piston calipers. Rear – Touring system 12 inch slotted/cross drilled, zinc washed rotor, 1 piston calipers
Stainless and or braided stainless lines throughout
Wheels
Budnik Hammer Brushed center, polished hoop, soft lip
Front – 18 X 8 with 4.75 back spacing
Rear – 18 X 9 with 5.375 back spacing
Tires
Nitto 555 Extreme
Front – 235/40/18
Rear – 275/40/18
Electronics
Painless wiring complete 18 block wiring harness
Auto meter gauges
Ignition
MSD 6 Ignition
MSD Pro billet distributor
MSD 8.5 mm plug wires
Stereo
Alpine 9835 receiver, CD/MP3/WMA, electronic crossover, 3, 4 volt outputs, 7 band equalizer,
Polk Audio Momo series C500.1 Mono block amplifier 350 X 1 @ 4 ohms
Polk Audio Momo series C400.4 amplifier 100 watts x 4 @ 4 ohms
Pair Rockford Fosgate T2 10 inch subwoofers in sealed Q logic box
2 Pair Polk Audio MMC650 6.5 Inch co axial with external crossovers
zbugger
04-26-2006, 07:37 PM
Welcome to the site!!!
importkiller69ss
04-26-2006, 08:04 PM
i like the seats what kind are they? the rest of the car looks killer welcome to the site
DReid
04-27-2006, 04:09 AM
Without looking I want to say ARC - the material is what got me it's a carbon fiber looking vinyl and looks great. Bought a roll for the back to match and it turned out great. As far as the seat??? Not thrilled with the comfort or rollers instead of levers but the look was key at the time
mikey
04-28-2006, 08:48 PM
Thats sweet I really like your color choice:twothumbs
Ralph LoGrasso
04-29-2006, 11:41 AM
Welcome aboard.
NvrDun71
04-29-2006, 03:27 PM
Welcome to the site man. I have seen your car out at the Spring Cypress street meet, and your pics don't do it justice. The car looks great and I love the Budnik's. Definitely a cool meet out there.
I Hope to have my 71' Nova back on the road this summer and make a few trips out there:3gears:
restomodbird69
04-30-2006, 05:27 PM
welcome ,i too am on the nw side of houston,my 69 bird is in paint now i would like to see yours in person sometime.
69rs
04-30-2006, 06:04 PM
Wow, nice ride! Top shelf components, too! Welcome to the site!
I thought they only liked stock cars over at Camaros.net. I've only been there a couple of times, but that's what I had heard.
Camaro Zach
04-30-2006, 06:23 PM
Welcome aboard
