View Full Version : LQ9 Options
Lawrence
04-22-2006, 12:24 AM
There arent a lot of LSx engines going cheap in the UK, and when I found an LQ9 on ebay for not a lot of money I bought it. I've got 3 LT1's, and now I've got an LQ9 that I cant swap stuff into :hand:
Right so what year auto gearboxes can I use on this? I have a '95 4L60E sat spare, along with a 4L80E. Can you only use the late split bellhousing ones with these? I was planning on running a factory PCM, but open to suggestions.
nitrorocket
04-22-2006, 05:36 AM
Yes, you can bolt up the trans to your ls1, but one belhousing bolt will not be used, so only 5 will be holding the trans on. No big deal. I have almost 1000 hp and mine is still holding on strong! You can use any auto gear box.
Whistler
04-22-2006, 07:16 AM
Any year trans will bolt up, but the flexplates and torque converters are all different.
I was under the impression that the 98-up 4L60E was the only one that would work with the factory LS1 PCM. I may be wrong though. I know you can bolt up any older non computer controlled trans, like a 700R4, TH350, TH400, P-Glide, by using 5 of the 6 mounting holes, and using the correct flexplate.,
Lawrence
04-22-2006, 01:42 PM
I realised they would all fit physically, it was if I could use a stock PCM and one of the boxes I already had?
