Results 1 to 7 of 7
Thread: What order to do this in?
10-14-2004 #1
I'm finally starting on the mini tub project of my '69 Camaro and have a question about replacing the outer wheel wells at the same time. The quarters need replacing, but that will have to wait for a while. Should I replace the outer wheel wells when I do the minitub, or tack the widened inner wheel wells to the factory, rusty outers and replace them when I do the quarters?
Nathan
10-14-2004 #2I replaced my outers at the time I did the mini-tub. The reason being that the outers are supposed to install before the inners. If you don't do this while replacing the inners, you will have to remove the inners to install the outers. Did you understand that? lol
Bill
68rs mini-tubbed,subframe connectors, 335's on Fontanas
10-14-2004 #3I missunderstood your first post about just tacking the inners. Anyway its probably a good idea to do both at the same time as I found that it helps to have both tubs free for adjustment. Plus if you are getting the outers from Goodmark or probably any other aftermarket supplier, they are going to be stamped in Taiwan or China and they probably won't be an exact replica. Mine took a little tweaking.
Just my two cents.....Bill
10-14-2004 #4
