    Results 1 to 5 of 5
      Oakland CA
      Drum vs. Disc Brake hubs when doing ls1 swap...
      Am i gonna have problems using a disc brake hub while doing an ls1 brake swap?
      :3gears: 68 Rally Sport Camaro 350/4spd(t56ingarage)/8.5 10bolt 2.56 open,Hotchkis springs, kyb shocks, 17" Rallys 235/245-45-17
      1989 Pontiac Turbo Trans Am 3.8 Buick LC2 V-6 w/51k, Ported heads w/oversized one piece valves, te-44 turbo,PTS built 200R4 w/2800stall, Lucas green top 009 42.5# injectors, AFPR, Adjustable wastegate, ATR 3inch exhaust, Terry houston 3inch mandrel bent downpipe, stock intercooler w/duttwieler neck, Eibach Springs, Bilstien shocks, Spohn adjustable panhard bar...
      Quote Originally Posted by 68RallySport
      I think you need the drum brake hubs
      76 Firebird
      99 LS1 M6
      99 F suspension
      99 dash,seats
      air bags,ABS
      C5 F brakes
      AC CC TW
      17x9 275 F
      17x11 315 R
      zachary louisiana
      yes on a first gen there is no hub to hold the bearing it is a one peice with the rotor.. you need to use the drum hub b/c thats what has the bearings and studs when using the ls1 rotors....i think however you can use the spindles
      1969 camaro ss 372,hotchkis tvs, comp cams 268xe, world products heads, zz4 intake, 670 holley, msd setup eagle alloy 212's, autometer ultra lites......99 console with megashifter, ls1 brakes and a soon to be 700r-4
      http://http://www.cardomain.com/ride/2246580
      Scottsdale AZ
      68Rallysport:
      I just went through this whole conversion. Do yourself a favor and contact Tobin at www.kore3.com or Noel at www.touringclassics.com (site sponsor at right).
      Both make everything you need and in the long run you will be about the same price but much happier and much safer.
      Dublin, CA
      Brickyard- Suppose it depends on what you are looking for. Kore3 makes nice stuff, but I can not see spending $275ish for aluminum hubs when you can make your own. There is less weight to the aluminum hub, but no difference in functionality IMO.
      Unless you were looking at all new prices I am not sure how buying from Kore3 would be cheaper than fabrication the conversion pieces yourself- I just did mine for under $250 for everything. Plus, there are the wheel size issues with the C5 13" rotors.
