    Results 1 to 3 of 3
      Oakland CA
      Difference between ls1 camaro and c5 vette calipers???
      What are the major differences? Is the mounting the same?
      :3gears: 68 Rally Sport Camaro 350/4spd(t56ingarage)/8.5 10bolt 2.56 open,Hotchkis springs, kyb shocks, 17" Rallys 235/245-45-17
      1989 Pontiac Turbo Trans Am 3.8 Buick LC2 V-6 w/51k, Ported heads w/oversized one piece valves, te-44 turbo,PTS built 200R4 w/2800stall, Lucas green top 009 42.5# injectors, AFPR, Adjustable wastegate, ATR 3inch exhaust, Terry houston 3inch mandrel bent downpipe, stock intercooler w/duttwieler neck, Eibach Springs, Bilstien shocks, Spohn adjustable panhard bar...
      Mounting and dimensions are the same. C5 are pressure cast aluminum whereas the LS1 are gravity cast. C5 are supporsed to be stiffer and resist flexing under heavy braking a little better. C5 have 40mm pistons. I think LS1 are the same, but I have also heard that they are 44mm.
      Jeff
      1970 Corvette
      LS1 & T56
      C5 Z06 Brakes
      Quote Originally Posted by 70 LS1
      The LS1 calipers have bigger pistons, not sure what size.
      The bracket or basket for C5 has 14mm mounting bolts,
      & LS1 basket has 12mm. Dale
      76 Firebird
      99 LS1 M6
      99 F suspension
      99 dash,seats
      air bags,ABS
      C5 F brakes
      AC CC TW
      17x9 275 F
      17x11 315 R
