    Results 1 to 5 of 5
      charleston, SC
      Wilwood Tandem Master w/Hydraboost
      I've got a question. I'm trying to install the Wilwood Tandem Master Cylinder in my car now. I'm having some trouble with the rubber boot that goes over the piston. How does it fit into the Hydratech booster? I doesn't seem to fit inside the booster when I tighten up the nuts.
      Robert's 1969 Camaro - 2002 LS1/T56, 10pt cage, Global West Stage III front suspension, HTH truck arm rear suspension, Sprint Cup 9" full-floating rear end, Fikse Mach V 17" up front 18" in the back and still working on it...
      Harriman, Tennessee
      I believe that you use the boot only when using the master cylinder in a manual application.
      Shiny Side Up!
      Bill
      '72 442 "Inamorata"
      "You can never go home again, Oatman...
      But I guess you can shop there."
      charleston, SC
      That makes sense, but now I think I have the wrong bore size. The master cylinder just bolts right up without any type of seal. I'll have to check when I get back home.
      charleston, SC
      My '69 Camaro Assembly manual shows a gasket between the booster and the master cylinder.
      Harriman, Tennessee
      Hmmm... I've never see one on there, but they may have had them.
      Shiny Side Up!
      Bill
