    Results 1 to 11 of 11
      Oakland CA
      LT1 rear brake swap...
      Getting all the parts together for the brake swap. I learned that u need to right side caliper brakets to clear the 68 camaro staggered shock setup. My question is do i need two right side calipers??? Or do i use a left side caliper with a right side bracket???
      David
      :3gears: 68 Rally Sport Camaro 350/4spd(t56ingarage)/8.5 10bolt 2.56 open,Hotchkis springs, kyb shocks, 17" Rallys 235/245-45-17
      1989 Pontiac Turbo Trans Am 3.8 Buick LC2 V-6 w/51k, Ported heads w/oversized one piece valves, te-44 turbo,PTS built 200R4 w/2800stall, Lucas green top 009 42.5# injectors, AFPR, Adjustable wastegate, ATR 3inch exhaust, Terry houston 3inch mandrel bent downpipe, stock intercooler w/duttwieler neck, Eibach Springs, Bilstien shocks, Spohn adjustable panhard bar...
      Oakland CA
      Nevermind i thought about it harder and well i dont think u could even use a left side caliper with a right side bracket! Guess taht means two rights!
      Germany
      I'm preparing a similar swap with Corvette LT 1 brakes (big brake option)!
      The brackets are the same for left and right.
      What setup for the emergency brake for your swap you will use?
      I skip the staggered shocks and will change the sides of the calibers because of the bledding screws. The calibers are between axle and trunk (At the Vette LT 1 tha are in front of the axle)
      Night Rider => My car
      69'Camaro
      92'Corvette LT1 engine, 4L60, shorty headers, Flowmaster, Eibach, Vette wheels=> soon coming:hotchkis leaf springs nova rear w limited slip, Corvette brakes
      Oakland CA
      I thought the brackets where different side to side? I already know im gonna need a custom ebrake cable and it looks like its gonna be hard to fabricate but we will see when the time comes. Ill make sure to take plenty of pictures!!!
      May 2000
      The brackets are in fact different from side to side. If you have staggared shocks, get to right side brackets and two right side calipers. Done it.
      Germany
      I spoke about Corvette LT 1 brake caliber brackets and I think they are not different. But I will check this tomorrow.
      69'Camaro
      Oakland CA
      Any pictures???
      This guy did his 68 which maybe similar to what you are doing, has pictures and detailed explanation
      Oakland CA
      Torose i dont see any info? Who, what and where? I have done a bit of reasearch looking at David Pozzi's page and links as well as Torkers site which all had really good info...
      David
      May 2000
      Just get the two right side calipers and brackets and you're good to go. It's easier then taking the drums off, lol.
      Jun 2001
      Newbury Park, CA
