Results 1 to 7 of 7
Thread: Media blast...now what ??
04-07-2006 #1
I'm getting ready to media blast my car and wanted to get a plan on what to do after I get it back.
I've also been researching epoxy primer vs self etch primer and which is better for bare metal.
I'm planning on using etch primer to seal up the metal, but havent decided on which brand.... I'm leaning towards PPG.
So.... should I run a DA over it ?? Which grit ??
Then how should I prep/clean the metal before spraying the primer ?? Wax and grease remover, paint thinner ??
I want to do this right the first time.......
Ned
Manteca, CA
My '69 Camaro
My Camaro Movie
My '70 Cuda Project Thread
My Cuda Project Pix
Cuda Project Sponsors/Builders
Bruning Auto Design,
Bowler Transmission, Air Ride Technologies, American Autowire, Vintage Air, Comp Cams/F.A.S.T
Carter Hickman Designs
04-07-2006 #2
- Join Date
- Apr 2005
- Location
- Baltimore, Maryland
- Posts
- 32
Yeah I'd really like to hear this too. My Nova's about to be shipped out to the blasters as well. Don't want to have to do it twice!
04-07-2006 #3Well I guess it depends on the grit media being used. If you can rub a shop rag over it and it leaves visable lint attached, then it is too coarse of a surface to just lay down a sealer (unless you want to waste alot of sealer). I would recomend going over as many large flat panels as possible with a 180 grit, then lay a direct to metal sealer/primer.
Dave @ Camaro Specialties
http://camaros.com/
04-08-2006 #4
- Join Date
- Oct 2004
- Location
- Oswego il
- Posts
- 938
