View Full Version : Big Block 69 camaro header clearance ?
Whistle Pig
04-03-2006, 04:01 PM
Anybody have a solution to my drivers side header being right up against thesteering box. Looks like a small dent would work yet a large one would be needed to get the power steering hose back in.
Has anybody used a 90 degree angle fitting for the line?
How about a different gearbox? :banghead:
The mounts are all new big block mounts, trannys bolted in????
The engine appears to be where its supposed to BE !
Hooker headers, bought used ( comps? )
TIA Kevin
Whistle Pig
04-04-2006, 07:29 AM
Moderater
Could you please move this thread to the correct locatinif possible?
Thank You
MyRodd
08-03-2011, 11:08 PM
TIA Kevin
Hi Whistle,
I was curious if you ever found a solution to your problem of your header hitting against the steering box. I've had this issue for many years and have never found a good solution? Any specific kind of header you end up using? Any help is greatly appreciated. Thank you.
67 ls1 vert
08-03-2011, 11:41 PM
doesnt look like he has loged on in over 4 yrs.
I have a friend that has the same problem. He just ordered a set of Lemon headers.
Maybe he will post up once he gets them installed.
