    Results 1 to 4 of 4
      Sep 2004
      How close can a tire be to leaf spring and still be safe?
      I am planning on running wider rims and tires and I am wondering just how close I can place the tire to the leaf spring and be safe from rubbing on corners and stuff?
      The tires will be 45 series and I will have a rear sway bar also on a 70 Charger RT.
      Farmington Hills, MI
      1/2in IMHO.
      JEff
      JEFF SHORTT
      -IDEAL STEEL
      May 2002
      Northern California
      With 17's or 18's you can get as close as 3/8". Ive had them at 1/4" with no problems. If your setting it up from scratch go with a half.
      Remember to watch out for the upper inner wheel house lip...you should be at least 3/4" away minimum from that. Your wheel will kilter up and in during certain manuvers.
      Outer lip can be fairly close too...i've been a 1/4" with little/no rubbing. Again depending on the suspension being used.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Sep 2004
      Yep, I will be running 18 inch tires. It seem the upper inner wheel well is the same distance from the wheel as the leaf spring.
      Thanks guys!
