vintageracer
03-17-2006, 06:35 AM
I was at the JY looking at the diamonds in the rough. I know that a late "metric" 78-81 F body subframe will bolt up to a 1969 Camaro/Firebird. Dimensionally the smaller crossmember (the one that makes sway bar installation a pain in ass) between the front crossmember and the radiator support is missing on this late subframe, the steering "front steer" instead of "rear steer" and the radiator support mounts are offset from the stock mounting of a first gen F body.
I know these subframes will bolt on a 1st gen F body and can be made to work with movement of the radiator support mounts, steering shaft modification and bumper bracket modification as a friend of mine did this years ago on his 1st gen 69 Firebird. Given this late "metric" subframe has taller spindles, better brakes, better suspension geometry with the taller spindles etc, this should be a good inexpensive upgrade to a first generation F body for those on a budget. I understand the last subframe 78-81 or metric is the one to use for this change. They are also VERY cheap at the JY. The best ones are off a WS-6 T/A.
How about some analysis as to why THIS IS or IS NOT worth the time to make this modification for those on a budget looking for a front suspension/subframe upgrade???
Opinions???
Opinions???
