View Full Version : Which engine/light harness should I buy?
streetk14
03-11-2006, 04:26 PM
Ok, I have the entire front clip off my 68 Camaro. I'm installing my WD C4 subframe, a new engine, and basically cleaning everything up. Hers's my question: I want to replace my original engine wiring harnesses. My car was originally a 327 car with warning light gauges. I have always run mechanical gauges in the past, but I am considering using a Covan's dash panel w/ electric gauges and their gauge harness to make things simple. I've been looking at my Classic Industries catalog. They offer 2 harnesses for my car (one for factory warning lights, one for factory gauges). Which one should I get, and does anybody know what the difference is between the two? Will the factory warning light harness wires work with the autometer sending units? I'd assume the autometer gauges simply take the place of warning lights. It appears the factory gauge cars used a mechanical oil pressure gauge, so a sending unit wire is not part of the harness. It seems as if the warning light harness would be a better choice. Anybody have experience with this? Opinions?
-Andy
Rick Dorion
03-13-2006, 05:07 AM
Although I've used Factory Fit for stock replacement ( excellent products), I would call them and explain your needs. They can either steer you to the correct application or create a harness for you.
ProdigyCustoms
03-13-2006, 07:05 AM
Hey Andy,
Call me when you are ready to order. I am real familar with AA stuff. They make a covan harness to go with their harnesses. just give me a call, I talk better then I type. Also we can get you a better price then Classic.
