View Full Version : Fat lip?
Damn True
03-09-2006, 08:07 AM
Anyone have a photographic example of the same wheel in fat and non-fat lip design?
I don't quite get what the difference is.
Scream
03-09-2006, 08:11 AM
Vintec with classic hoop:
Vintec with soft lip:
Notice the difference? There are no "steps" between the outer edge of the hoop and the face of the wheel.
BADVELLE
03-09-2006, 08:14 AM
One has the tradiyional "stepped" lip, the fat lip is smooyh to the edge of the wheel.
Travis B
03-09-2006, 08:27 AM
the tire has to go on from the back on a soft/fat lip style
1981silverz28
03-09-2006, 11:51 AM
Fat lip gives a 17" wheel the look of 18" so you can run a little more sidewall and still have a big wheel look.I think they look great!!!!!
Ralph LoGrasso
03-09-2006, 01:11 PM
Side View (excuse the rusty rotor):
Stu Seitz
03-09-2006, 09:03 PM
They also cut down on clearance for break caliper clearance.
JasonSS
03-15-2006, 04:23 PM
if that you mean by 0.20"@max back space. Other wise The Fat-Lip outer has a larger ID @ min back space than a traditional lip.
baz67
03-15-2006, 05:53 PM
Uh no. It has a larger ID on the outboard side of the rim, but it still has the hump. It was just moved more towards the center of the rim. Hence the less brake caliper clearance. Ask Larry about that.
lower90xcab
03-16-2006, 06:23 PM
Here are the wheels im running on my pro-touring themed 98 Sonoma. They are 17x8/10's with 4.5 backspacing. The where made by Intro and sold by CoysWheel.com out of Utah.
protour_chevelle
03-16-2006, 06:37 PM
This is the best I could find...
Fat Lip
https://static1.pt-content.com/images/pt/2006/03/Jimmy20fat20lip20right-1.jpg
Normal Lip
https://static1.pt-content.com/images/pt/2006/03/ourlipsaresealedmarykateashley-1.jpg
-Matt
Modo Innovations
03-16-2006, 07:50 PM
I love the Fat/Soft lip design, but it does have a draw back. I found this out after I received my BOYD "FURY" wheels (17x8 up front). If you are running C5 rotors (13") and Z06 calipers you will have to grind some of the height off of the fins on the caliper. They drag just ever so slightly. There is a step on the inside of my wheels that the caliper interferes with. I did notice in the pics above in the earlier post that those wheels have the same inner lip that I am refering to. I don't know if ever Fat/Soft lip wheel has this issue or not but mine did. It wasn't a big deal to fix it was just unexpected.
