    Results 1 to 7 of 7
      zachary louisiana
      what studs to use with ls1 brake swap
      i am about to finish this up and need to know what studs to get for the front i know they have to be longer but where can get them..napa carquest ect.....thanks
      1969 camaro ss 372,hotchkis tvs, comp cams 268xe, world products heads, zz4 intake, 670 holley, msd setup eagle alloy 212's, autometer ultra lites......99 console with megashifter, ls1 brakes and a soon to be 700r-4
      http://http://www.cardomain.com/ride/2246580
      Nov 2000
      O-town
      Dorman Products, check your parts houses with a Dorman catalog
      Clovis, Ca
      When I did a C5 front swap on a 68 Camaro I used Napa Pt#:
      641-1267 7/16 X 1-3/4" studs and they were about the right length
      if you want a little longer stud use Napa PT#
      641-1268 These are 7/16 X 2-1/8". If you use a cone style of lug nut these may bottom out in the lug nut.
      zachary louisiana
      what do you consider a cone style lug nut...
      Mountain View, CA
      Not open ended.
      True T.
      My blog
      zachary louisiana
      ok so i should probably use te firt part number then
      Clovis, Ca
      I used the long 2-1/8" inch studs w/ cone style nuts and they worked but were Very close to bottoming out. The wheels on the car had fairly thick mounting web so it worked out.
      I would suggest going down to Napa and buy a couple of each and try them out and see what works best. They are not that expensive so you will only waste a couple bucks and you will have the right studs for your app.
