    Results 1 to 11 of 11
    Thread: 12" C4 rotor
      Jun 2001
      Newbury Park, CA
      12" C4 rotor
      Gentlemen, I need a favor.
      Does anyone have a 12" C4 rotor laying around that can take the following measurements?
      Diameter (tape measure +/- 1/16" is fine.)
      Thickness of the friction surface.
      Backspace (distance from the inboard friction surface to the inboard mounting flange.
      Thanks!
      Detroit, Michigan
      Carl I am installing my brakes from Touring Classics and I have a loose 12" rear rotor. When I get home I could take those measurements.
      Sep 2001
      Accord, NY
      Carl, I can check tonight. I have a set that never went on the car.
      69 Camaro convertible, 410, M22, 8-pt cage therapy program. SOLD.
      68 camaro - SOLD
      67 Bel Air - New street project with perfect floors, frame and trunk!
      Sep 2004
      florida
      according to my catalog here at work the diameter is 12" exact, the height is 2.205" and the discard thickness is .724" so i would guess new would be around .735? i dont have an actual rotor to measure but those are the specs that napa provides me
      Tough guys may wear pink, but Bad Asses still wear black.
      I found a nominal thickness figure of .787" and min machine thickness of .744" discard thickness at .724" on www.autozone.com if that helps
      Aug 2005
      Ashland, Oregon
      specs according to our books are as follows 88-92:
      O.D. 12.0"
      Height 2.20"
      Nominal thickness .783
      minimum thickness .724
      wheel register 2.780
      Jun 2001
      Newbury Park, CA
      Thanks!
      Sep 2001
      Accord, NY
      Carl, do you have all the info you need?
      68 camaro - SOLD
      Jun 2001
      Newbury Park, CA
      Quote Originally Posted by Rick Dorion
      Yes. Thanks for the follow-up!
      Quote Originally Posted by CarlC
      Just a heads up on the C4 12" rotors. The offset between the front and rears are different. Not by much, about 1/8" or 3/16" (can't quite remember). Can be used to slightly adjust the position for better fit up to the caliper location.
      The rears have the lessor offset.
      Bob.
      Jun 2001
      Newbury Park, CA
      Bob,
      The 93-7 Z28 rotor is 11-1/2" diameter, while the C4 front is 12". However, as you mentioned, the offset on the C4 is 1/4" more. There's not enough difference in size to make the swap viable, not to mention the re-fabrication of bracketry to make up the difference in offset.
