    Results 1 to 3 of 3
      Nov 2004
      San Antonio, Texas
      Lokar gas pedal for 68 camaro question
      i widened my tranny tunnel and eliminated the factory gas pedal in the process. i was wondering which lokar gas pedal would work the best? the eliminater or the firewall mount?
      Feb 2002
      Santee, CA
      Lokar Gas Pedals
      If you widened your tunnel to the point that the original gas pedal will no longer fit, then the firewall mount one probably won't either since it mounts in the same spot.
      I needed to go with a cable based pedal assembly to support my EFI setup. I originally went with the firewall mount, but I didn't care for how it worked out (too high for one thing). I later swapped it for the floor mount (eliminator) and I absolutely love it. It is a much larger pedal and it puts the cable lower on the firewall (almost out of sight). Sorry I don't have any pics of the new pedal assy, but here's a shot of the firewall mount.
      ---Eric Senior
      Huntington Beach, CA
      How bout a pic with the floor mounted one if you get a chance!
