    Results 1 to 4 of 4
      Dublin, CA
      Help, conversion bracket woes!
      Critical reading has never been my strong suit. I have purchased front and rear LS1 camaro brake components, only to find that the brackets available for the front seem to be for 1st gen only. No issue with the rear, but does anyone know of a conversion bracket being made for a 2nd gen Camaro? I can sell the parts, but would really like to make this work.
      Is the hole spacing the same between the LS1 and C5 abutments? If so, couldn't I just drill out the LS1 bracket for the larger 14mm bolts and use a C5 bracket and buy the larger 13" rotors? Or would this cause strength issues?
      Brent
      Sep 2001
      Accord, NY
      I think they're different brackets. The LS1 and C4 are different. I shouldn't read so fast - missed the 2nd gen statement. Sorry.
      69 Camaro convertible, 410, M22, 8-pt cage therapy program. SOLD.
      68 camaro - SOLD
      67 Bel Air - New street project with perfect floors, frame and trunk!
      Medford, OR.
      Brent,
      PM sent
      Laramie Torres
      Montgomery, IL
      some helpful info on what needs to be done:
      http://www.geocities.com/diels12000/BrakesII.html
      brackets and stuff:
      http://www.kore3.com/products.php?cat=11
      71 Formula, 455 SD/KRE D-Ports, Crower solid cam, TKO 600, 3:73 Eaton posi. 17" ARE 200s, , 1LE brakes, Koni, Rancho adjustable bars, Hotchkis springs
