View Full Version : LS1 Carb/distributor question
67convertible
02-23-2006, 01:35 AM
I know there are some good carb manifolds for the LS1 available. But is there a conventional electronic type distributor avaliable? Couldnt find one through internet search. Any ideas?
Thanks, John
rocketman
02-23-2006, 06:56 AM
no.you will have to use msd or edelbrock eletronic's.there's not that i know of either.
TMat
02-23-2006, 07:02 AM
I saw an article in one of the magazines that converted an LS1 to carburetion and they used a front drive from GM that included a ford distributor and a mechanical fuel pump drive. I think it was chevy high performance that did the article.
gen3bu
02-23-2006, 06:41 PM
look at nineball's pix on here from this years pri show they are on there way. i think he had pix of 3 diff companies making them. wegner, gmpp, and ???
it uses a front mount hei.
Van B
02-23-2006, 09:33 PM
Wegner sells a setup that will use a distributor and one that does not. Give Dan at Wegner Motorsport a call.
http://wegnerautomotive.com/wegnerautomotive/index.htm
That is my engine on the top of the homepage.
parsonsj
02-24-2006, 10:57 AM
I'll second Jeff's recommendation. The folks at Wegner know more about running a carb on an LS1 than anybody. Wegner did the R&D for the GMPP manifold.
Give Dan a call, and he can sort you out.
jp
67convertible
02-24-2006, 11:55 AM
Thanks for your help and recomendation. I will try to contact Wegner. Their setup looks good.
>Will try to post pictures on the weekend, but I`m not really good with this....
67convertible
02-25-2006, 08:52 AM
Does anybody now, if the wegner front cover comes with all necessary spacers and so?
It looks to me, as if the cover incorporates a stepout for the distributor drive. So the water pump must likely be moved further out. Does that mean, that I would need another pump or is this done by spacers?
Can anyone supply me with good closeup pics? Wouldnt be nice to order something and have it shipped overseas, to find out it won´t fit.
Thanks guys, John
Van B
02-25-2006, 12:33 PM
It might be easier for you to shoot Dan an e-mail, I did not realize you were in Germany. [email protected]
You may have to use their water pump with the distributor drive.
Here are some pics that Nineball took at the PRI show.
http://www.ls1tech.com/PRI_2005/pages/DSC00957.htm
http://www.ls1tech.com/PRI_2005/pages/DSC00951.htm
http://www.ls1tech.com/PRI_2005/pages/DSC00956.htm
parsonsj
02-27-2006, 07:30 PM
John,
Wegner has exactly what you need. They have all the spacers and adapters for however you want to do it: with distributor, with fuel pump, or whatever.
Call Dan, or send him an email.
jp
