tunerdude
02-20-2006, 03:20 PM
OK, here it goes. I got a 67 camaro for basically free. I worked on the guys fish tank for like 2 years to pay it off. I am only 21, so funds are limited. No rust on the car anywhere. Brand new 350 with hump heads, mild cam, 650 holley, and new turbo 350. Here is the problem.
It came with a fiberglass 2 inch cowl hood. I broke it off, on accident, forgot about the hood pins latching all the way, and it blew off at 80mph. Oh well, I hated the damn thing anyway. So I measure the clearance fore a new hood, and the engine sits about 1 inch higher then the hood line, so a stock hood wont fit. So I buy and install, with an orginal latch and assembly, a 2 inch steel cowl. However, I notice 1 of my motor mounts is busted, pass side. So I go to order new ones and find there are 2 sizes available. So I measure mine and it turns out I need the 327 block ones to match my frame mounts. Hmmmm. So I go back to the guy, he confirms that it was an original 6-banger car. I get home, run my numbers off the tag, and sure enough it was an 8 cyclinder car originally. However, no special engine code, so I figure it has to be an original 327 car. Which strangly enough is the engine it cam with before the 350. So heres the question...
Are the frame mounts different for a 327 and 350? Since I have a 327 motor mount and have a 327 frame mount, is this pushing the 350 up an extra couple inches? The 350 has a taller deck size right? If so, could I get a 350 frame mount and 350 motor mount thus lowering the engfine a few inches for a lower center of gravity and less likely to break a motor mount?
Thanks alot for all the help. and yes, it has a torque strap.
-Brandon...sry for long post.
