Railing68
02-19-2006, 06:27 PM
Follow up on a prior post.
Well after having the front re-aligned -1.0 camber, +6.0 caster, and 1/8" toe in I re-fit the fronts with the nitto 0-1s 245-45-17 and they clear. I had to remove the lower inner fender bolt and I will replace it with a pan head.
I realize that many have run this size on first gen but, I had serious issues prior to re-alignment. I will be using -1.7 camber for auto-x, but I test drove at current -1.0 and everything seemed good.
I would think that the added neg camber shouldn't create any additional issues and should tuck the top of the tire in slightly. Any oppinions on this?
After several parking lot tests, only minor rub on the pass side close to full crank 90+*turns I had to really try to get it rub, off camber is of course worse. So a short story-long is am going to be able to run this size on all four corners.
The compound is really sticky I can notice a big difference compared to my 225 50 16 sz50ep. I can't wait to really push them. :cool: SS
